Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 71
Thread: Control neon lighting, lights, amps, etc from pc?
  1. #41
    FLAC guitar333's Avatar
    Jun 2003
    IDAHO
    i know mastero had it coded into ME but not 100% sure if it works with XP though. However there is commercial software I found that does work with XP I posted a while back.
    92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
    93 Black SHO - 30mpg cruiser
    90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
  2. #42
    Dec 2003
    Birmingham, AL
    Quote Originally Posted by guitar333
    I've looked through your previoius posts, but the only thing I see is something about an eBay auction on this topic.
    Can you post links to the comercial s/w you were talking about?
    Also, you're running XP, right? What are you using to do the relaying activities?
    thanks again,
    .brit
  3. #43
    Jun 2003
    IDAHO
    dang. it prob shows "invalid item" when clicked huh? I forgot the website. I wish I know. It comes with XP software. neon lights
  4. #44
    Dec 2003
    Birmingham, AL
    What are you using?
    .brit
  5. #45
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    i'd like to get into this conversation. i have been using wizards program since he wrote it. works great. i also installed a delay circuit on the relay board so as not to get a turn-on thump in the amps from the computer. its set to go on after windows boots. this also keeps the relays from clicking on and off when booting-just a coincidence. but i would love to use xp on this computer so if anyone has a version that works i'd like to try it out.
  6. #46
    Dec 2003
    Birmingham, AL
    Quote Originally Posted by albysure
    What OS are you using?
    .brit
  7. #47
    Dec 2000
    pittsfield, ma.
    me
  8. #48
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Whats so hard about buying a relay and then hooking it up to a parrallel port then sending 1 to the data pin to power the relay and turning the device on????
  9. #49
    Jun 2003
    IDAHO
    im not sure but i remember reading that with XP there is a new thing that doesnt allow parallel port manipulation or something like that
  10. #50
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    Quote Originally Posted by owenjh
    You might end up drawing too much power and blowing something on the i/o card or worse...the motherboard. a buffer system is used so that if too much power is drawn, the buffer system will blow, only costing a few dollars compared to $10-200...
