Results 1 to 10 of 19
Thread: sony joystick??
    Newbie asteroid's Avatar
    Jun 2001
    Portsmouth UK
    Question sony joystick??
    anyone seen those Sony joysticks you can buy as extras for Sony car stereos? I think there is a small wire you hide inside the care dash which the joystick glues on the steering column next to you wiper/lights switches.
    As this is just a bundle of switches, could this be easily hacked and wired up to a joystick or keyboard port?
    sounds like it would be a neater solution than a keypad. I think I have seen the joysticks for about UK£20.
    I am only building a home player, as I dont have car, but Im just curious
    John H
    Apr 2001
    Here, There, Everywhere
    Post
    check out this link...... I think it might be on the track of what you are after....
    http://mysite.ciaoweb.it/casahardware/car_mp3.htm
    not english, but a circuit diagram and a winamp plugin screenshot.... should give you a good hunting start.....
    Project - GAME OVER :(
    Jan 2000
    Post
    http://www.bjnet.demon.co.uk/Empeg/Empeg.htm
    That link leads you to a guy who did the sony joystick mod for his empeg, might be a starting point, and he includes his source
    topperge
    May 2001
    Thessaloniki, Greece
    Question
    Magnetik,
    that link you posted is broken. What did this guy manage to do with the Sony joystick remote? Controlled winamp?
    If that's what he did, could you post a working link?
    Oms
    Oms is offline
    May 2000
    The Netherlands
    Post
    Funny, I just happened to post about it in another thread.
    It's actually an "analog" device. Every switch activates a different resistor, except for one, which is a "true" button. So you wire it up to the joystick port, and read a joystick axis to tell which switch has been pressed. Anyway, I've got it working, based on info I found here:
    http://llg.cubic.org/tools/sonyrm/
    You have to put together a small circuit for the joystick port, _AND_ write some software. Unless you use XMMS under Linux -- in which case just get the XMMS module on the page above.
    Custom Linux system on an '89 VW GTI 16V Edition One
    Jogdial volume control, Sony joystick, IR remote...
    Used to be the fastest Linux on the road, until all these NOS types came along...
    May 2001
    Question
    Oms,
    could you do me a BIG favour, please?
    Could you test your Sony joystick on a Windows+Winamp computer and tell me if it is working properly with one of the three existing joystick control Winamp plug-ins?
    Do you happen to know any other software/plug-in that let's you use it?
    I wouldn't like to buy the joystick and build the adapter for no reason.
    Dimitris
    Oms
    Oms is offline
    May 2000
    The Netherlands
    Post
    Dimitris -
    No, it won't work with Winamp plug-ins, at least not until someone writes a plug-in specifically for the Sony. (Aren't there any Windows programmers on this forum? Hello?)
    Reason is, the Sony works by shunting in a different resistor for every button. To the computer, it appears as if a joystick has been moved along the X axis to a certain very precise position; every button corresponds to a different position... it's a fairly unique setup, so no generic plug-in will work.
    May 2001
    Question
    Thanx Oms!
    Unfortunately I don't have a clue when it comes to programming.
    So... any programmers out there interested in this Winamp control alternative? I could make a very proffessional looking solution!
    Dimitris
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    Post
    Wow, my neurons are firing faster than a gatling gun.
    If you could let me know where I can find a circuit diagram for the Sony joystick, I'm 99% sure I could creat an interface circuit to allow it to be used with the existing joystick plugin, or even a key pad plugin
    On the side my idea is based around using the resistors as a potential divider, the output of which is connected to a series of comparitors, which then goes through some simple logic and into the PC, cunning!?!?
    Could one of the sparkies out there coment on this idea and possible recermend a comparitor chip.
    Rob
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    May 2001
    Post
    [ 01-30-2002: Message edited by: Dimitris1976 ]
