Results 1 to 4 of 4
Thread: Solution the provides USB input, SD Card Reader, and Aux input for carputers?
    Oct 2005
    Southern Maryland
    Hi everyone, I've been doing some searching but have come across such a product that will connect to a carputer somehow. I'm looking to see if there is any hardware that can be connected to carputer via USB (or maybe RCA/3.5mm jack) that can be mounted remotely and provide inputs for USB audio, SD card, and Aux in. I know I could obviously run a separate cable/component for each of these type inputs I would like to have, but I'd love a hardware interface of some sort that combines the 3 of these inputs into one piece of hardware that can be mounted somewhere near the dash, in a center console, or in a glove box. Thanks in advance!
    -Andrew
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Your best bet may be to get a USB hub, and run that to a USB panel connector, SD card reader, and a USB sound card with ports panel mounted. Then you only have to run one USB cable for all of them.
    RevFE
    My Shop
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    They have things like this ebay item# 270853270858
    Oct 2005
    Southern Maryland
    Thanks so much for the replies, guys! Rray, I definitely like your idea for if I decide to mount something in inside the compartment of the center console or something. I think I might just end up mounting panel mounts for a USB port and aux-in... might just skip on the SD card reader, but not sure yet. The media dashboard definitely gives lots of options though! Thanks again fellas!
  1. Replies: 0
    Last Post: 10-27-2007, 06:33 AM
  2. Custom input solution
    By chris_j67 in forum Input Devices
    Last Post: 04-29-2005, 07:45 PM
  3. Replies: 3
    Last Post: 03-14-2005, 02:52 PM
  4. Fingerprint reader as input?
    By Yuriy in forum Input Devices
    Last Post: 01-11-2005, 12:02 PM
  5. A good input solution
    By 98_Prelude in forum Input Devices
    Last Post: 05-20-2003, 03:39 PM
