Results 1 to 7 of 7
Thread: Idea to keep standard stereo buttons
    Constant Bitrate KennyKen's Avatar
    England
    Question Idea to keep standard stereo buttons
    Hi All
    I havent been around for a while but i am thinking about rejoining the ranks and installing a new CarPC in my current car (2010 Ford Fiesta).
    however if your not aware the stereo in the for fiesta is quite unique, it has a front panel full of buttons, a separate small screen and a hidden unit which controls everything.
    For the last couple of years ive had a Chinese stereo installed which is based on Wince5 and is basically a Carpc that got terrible software and is drastically under specced. so i am thinking about keeping the 7" touch screen from this unit and stripping out all the electronics from the main unit and installing a new car PC. this is all great but it leaves me with 1 problem.
    I have to keep the existing stereo button because to blank them off would just look silly, and if i keep them then i would like them to control the PC...
    This is the issue i am stuck on at the moment. there are 30+ buttons on the panel, however there are only 14 pins on the plug. I am looking into using the RCJoyCon to accept the signals from the front panel and send them to the PC. so this leaves me with 2 questions:
    1) will the RCjoyCon work in the way i am wanting
    2) how can i work out which pin does what if there are only 14 pins then each button must share a pin with another button?
    here is a picture of the front of the stereo
    Thanks in advance and i'm sure there will be a few more questions to come later on
    Ken
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Welcome back Ken.
    You will really need to search online for a schematic/pinout for that unit.
    Maybe contact your ford dealer they might have some info.
    Ford forums would also be a good place to try/ask.
    Low Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, The Netherlands
    you have a big chance that e.g. the keypad has a data out connection , thats only 2 wires , and I agree with the above , try and find a pinout schematic for the buttons, thats your best bet
    View my worklog here
    England
    i managed to find a wiring diagram in my haynes manual :-)
    Its difficult to tell from the picture but the components on the top right of the image are:
    83 - Instrument panel console switch assembly
    84 - message centre control unit
    85 - audio remote controls
    I assume 85 is the steering wheel controls of which there are 5 buttons
    84 could be the original screen
    83 could be the button panel that i am interested in but that only seems to have 3 connections when the connector actually has 14 pins. Any ideas?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    3 sounds about right.
    12v in
    GND
    Signal.
    Now the buttons could either be done by having a different resistance to each one.
    or work on a BUS like the BMW iBus.
    If it is a very new Ford it might have CANBus as a lot of the newer cars seem to. in which case they might work off that.
    *Edit, in fact it does say CANBUS in the diagram so you do have CANBUS
    There are a couple of new threads about hacking the canbus, might be worth a look.
    May 2012
    Grandville, MI
    If you can get the factory manual for your vehicle you will come out loads ahead.
    It will describe much more about the wiring and what it all means since it is designed to tell a Ford Tech how to fix your car.
    Something like this would be great but if you do a search you can find others.
    http://www.ebay.com/itm/2010-FORD-FO...034b21&vxp=mtr
    Believe me, it is worth the cost of the books. I purchase them for every one of my vehicles now. The cost savings in repairs with one of these compared to a third party repair manual is incomparable.
    Maximum Bitrate PhilG's Avatar
    Mar 2009
    Ontario, Canada
    There are a couple of dash adapters out there that might work like this one http://www.crutchfield.com/p_1209958...k.html?tp=3486 if that helps you in any way.
  1. New Idea for AUDIO/VIDEO out of Tablets into aftermarket Stereo
    By reedickyaluss in forum Android Tablet
    Last Post: 09-30-2012, 01:11 AM
  2. Replies: 9
    Last Post: 07-30-2008, 11:14 AM
  3. can i upgrade my standard stereo software?
    By anthonytutton in forum Newbie
    Last Post: 09-06-2007, 12:25 PM
  4. Replies: 8
    Last Post: 05-11-2007, 06:50 PM
  5. Standard WRX with STi buttons - Convert DCCD into volume control knob?
    By Podaman in forum General Hardware Discussion
    Last Post: 07-08-2006, 03:50 PM
