Results 11 to 20 of 24
Thread: RGsB to Video RCA
  1. #11
    Nov 2012
    Quote Originally Posted by Roger555 View Post
    I want to do this too! I have a Scan Do I was planning on using but this would allow for a better screen while keeping the factory interface.
    You didn't happen to do this on an Acura TL? I have a TL and there was a guy on the forum that was working on a similar setup.
    I did this to my CTS-V.
    http://www.mp3car.com/worklogs/153699-a-macd-v.html
  2. #12
    Mar 2009
    yes its definatly RGsB, the reason I need to convert to Phono is so i can use a Lilliput touch screen for it
  3. #13
    Nov 2012
    RGsB can easily be converted to RGBs, then rescaled to 800x600 then converted to NTSC.
  4. #14
    Sep 2012
    Germany - Munich
    Ok. Please tell us how easy we can do that.
    Pal or NTSC is equal. I think my BMW system has an NTSC video output.
  5. #15
    Nov 2012
    Ok, I think this will help, some reading required!
    http://www.datasheetarchive.com/rgsb...datasheet.html
    http://www.ebay.com/itm/CNC-Monior-r...item4aac1700b8
    http://www.ebay.com/itm/NEW-SCART-RG...item337dfa167b
    http://www.ebay.com/itm/15Khz-RGB-RG...item35ba04e4ba
    This one worked for me.
    http://www.ebay.com/itm/170860805754...84.m1497.l2649
    What I did was use one of these:
    http://www.rakuten.com/prod/pc-lapto...ngId=177456953
    This gave me a "raster" (using composite video) so I could at least "see" the data (no blanking) and determine that it could be converted.
    There are chips that will "strip" sync off the green, then all you need is a re-scaler to convert the RGBS (comp sync) to a more useable friendly format (800x600).
    If you can take a picture of the display electronics or list the chips for the signal processing, you can reverse engineer what format the video is (usually).
    Also, just tapping these signals and trying to drive a chip or aux circuit may not work as they may have 75 ohm termination on the board that may have to be removed as the interface may have 75 ohm termination also, resulting in overloading.
    This sounds more complicated then it really is, you just have to be methodical in determining what the video is.
    The re-scaler board I bought works great, but I had to remove all the connectors from the board (to make it fit).
  6. #16
    Sep 2012
    Germany - Munich
    success BMW to VGA
    and here inside car with OpenBM Monitor:
  7. #17
    Nov 2012
    Congrats!
    Pretty neat conversion board huh?
    And it runs off 12 volts!
  8. #18
    Sep 2012
    Germany - Munich
    very nice board. but the difficult and confuse thing was, to find the correct cable to connect.
    yes, it works on +12V.
    Now, i try to get a composite signal, from vga.
  9. #19
    Nov 2012
  10. #20
    Sep 2012
    Germany - Munich
    if there is no other way, i will use this board:
  1. VGA to stock NAV RGBs/RGsB: research results and questions
    By RipplingHurst in forum LCD/Display
    Last Post: 10-06-2010, 04:40 PM
  2. [Video] - options for video output on iPhone/iPod touch
    By Bugbyte in forum iPhone and iOS
    Last Post: 03-01-2010, 05:17 AM
  3. BMW e38 video, RGsB question
    By toddc in forum MP3Car Products - store.mp3car.com
    Last Post: 10-21-2008, 03:32 PM
  4. Upgrade M1000 Video Driver, Now T868 Shows Incorrect Video Size
    By YellowBkpk in forum General Hardware Discussion
    Last Post: 11-03-2007, 12:22 PM
  5. Replies: 4
    Last Post: 05-10-2004, 06:23 PM
