Results 1 to 4 of 4
Thread: 78xx replacement
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    78xx replacement
    I have found this little gizmo and wondered if anyone has any past experience using them. They claim no heat @90% efficiency. SNO
    http://canada.newark.com/jsp/search/...sp?SKU=72R3616
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    And you can run them with no load, and do not require filtering. Nice find, perfect for powering USB devices.
    Raw Wave
    Nov 2009
    Noting that the analogs (79xx, 79xx, 317 etc) usually only require a minimum load of 10mA - eg, a LED or 500 (560) Ohm resistor. For the 317, a 120 Ohm resistor is often chosen for its 1.2V reference resistor (it could be larger if a LED etc is used across its outputs).
    I saw SMPS equivalents to 3-terminal linears ages ago, but they were never that cheap! So x2 - nice find!
    As to no heat... well, the ~0.8W at full load should be fairly insignificant, and is far better than the equivalent 13W from a linear.
    And of course the usual SMPS theory where no filtering should be required for inputs or outputs (HF noise excepted). (Strange that high power amps need max voltage for max output eh?)
    May 2007
    INDIA
    I suggest you have a look at switching regulators, they tend to give the most eff. and low heat, lm2575 - 1 amp. and lm2576- 3 amp.. these regulators come as standard 5v/12v versions and also adjustable versions. i have been using these for many years now and have found them to be very reliable.
  1. 700 TSV replacement
    By 2poor4mods in forum Xenarc Monitors Forum
    Last Post: 03-08-2010, 06:02 PM
  2. BMW e90 replacement bluetooth pc handfree replacement
    By dirtylarry in forum General MP3Car Discussion
    Last Post: 01-05-2010, 09:05 AM
  3. Replacement
    By joncole in forum General Hardware Discussion
    Last Post: 12-26-2007, 05:37 PM
  4. replacement TS?
    By theflygtiguy in forum LCD/Display
    Last Post: 09-12-2006, 07:17 AM
  5. t6 replacement
    By jure1873 in forum Power Supplies
    Last Post: 08-16-2002, 07:07 PM
