Those using D-Link USB radios. Question.
How do you link the Car antenna plug to the D-Link Phone plug for the antenna?
Currently I'm using a headunit and modulator, but plan for the next version to get rid of the headunit, and lose the modulator, and fit an Amp.
So how do you mate the Car antenna and the USB tuner Antenna connector?
well...I did some nice splicing, I got a RCA cord cut it nice, and got a male antenna end cut it and bonded the 2 ends, this workes!! my problem with my Dlink Radio is, when I plug it into my Line-In I get this horrible horrible Buzz on the line. so I have it disconected now.
till I figure out why it makes this buzz
Cheers. Figured there would be some splicing. I just wondered if some onad located a Car antenna to RCA adaptor or cable somewhere.
On the buzz front, try this.
"Unplug the antenna lead at the antenna in the trunk.
Measure back from the connector about 12 inches. Carefully cut the
insulation to expose the woven co-ax wire underneath.
Wrap some 8 gauge wire around the exposed woven co-ax wire and solder
together.
Cover and insulate the connection.
Attach the other end of the 8 gauge wire to the antenna mounting
bracket with a ring terminal. If you don't do the ground wire fix
above, I'd suggest testing the antenna to body ground connection and
repair bad grounds there if necessary."
it's actually from a Saab Newsgroup posting, about bad AM reception, but it could apply with noise generally.
Noise tends to be grounding issues. If the case is grounded, then look at the antenna. Maybe even pop open the Dlink, and find somewhere there to ground the antenna connection to the car chassis?
But cheers for the splicing tip. Wonder if I could get a naked RCA plug, and wired it to a length of Coax, or make a new cable from a cut off antenna cable, and get some kind of source splitter (so one antenna coudl feed several sources), so I don't have to butcher the original antenna cable?
I have one of those D-Link USB Radios ... but I can't seem to get it too work in WinXP ... am I missing something? I went to the D-Link website, but it says they no longer support that product. Is there some place I can go to learn about this before I go and drop money on an alternate FM solution for my PC?
I think it has something to do with the drivers. I think I saw on the site for Radiator that it is essentially a Gemtek USB radio underneith, and their drivers work.
Do a search for a radiator, supposed to be a very good piece of radio software.
I would be using it under 2k, rather than XP though, so I hopefully won't have that problem.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
