Results 1 to 10 of 12
Thread: Wont boot
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    Wont boot
    I am running an intel DG945GCLF and xp pro sp3.
    I had a working system until this morning. When I went to boot, windows wouldn't load. I tried safe mode and last config that worked several times. Neither would get me into windows.
    When I got home from work, I grabbed my xp install disk with the intention of using it to repair the install, or if that didn't work, reinstall a fresh copy. However, I loaded the cd into the usb cd rom drive and started the pc. The post screen flashes then goes black. On the bottom right hand corner of the screen is 94. I waited several minutes as the cd spun but nothing happens. The number 94 stays on the bottom right and I never get an option to boot from cd.
    I checked the boot sequence and cd is first.
    I removed the cd from the drive and it tries to boot again but it never gets into windows.
    I don't know what is causing this 94 issue. I used this dvd drive to install xp originally...
    Any thought about this guys? I would hate to have to tear apart my dash again to get at the pc.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    May 2012
    Grandville, MI
    Can you get into the Cmos on this computer?
    I suspect a bad hard drive or a loose card.
    Oct 2010
    The bios postcode: 94 is related to keyboard (Clearing keyboard input buffer). Try disconnecting all usb devices and see if anything changes. You may need to reset bios to default settings and see if computer boots.
    Nov 2007
    North Central PA
    Thanks for your replies.
    I haven't tried entering Cmos yet. I will try that today and see what happens.
    I will also try disconnecting all the usb devices. Would it make a difference if I told you I don't have a usb keyboard on this pc? I use a ps2 keyboard.
    I did already try to reset the bios to defaults but that didn't change anything.
    Nov 2007
    North Central PA
    Well I removed the pc from the dash. I pulled all the usb, reseated the memory, checked all connections, removed the cmos battery for 10 minutes. When I tried another reboot, I am getting an E9 error now.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    In the bios change your setting for all errors but keyboard and also are you giving it enough time to boot. Sometimes those boards take awhile when reset to factory settings. Just a thought SNO
    Nov 2007
    North Central PA
    Thank you for your response. Before I took it out of the dash, I left it on with the xp cd in for 20 min and I still had the 94 message. I only left the pc on for a few seconds after reinstall of the cmos battery. I'll try it for longer after work today.
    May 2012
    Grandville, MI
    Simply removing the CMOS battery will NOT clear the cmos. It has capacitors on the board to allow you to change the battery and not loose settings. You need to short across the contacts in the battery socket. Make sure you have your machine totally unplugged from any power source when you do this however.
    Nov 2007
    North Central PA
    Thanks for the tip. I think I may have done that by accident. I put the battery in backwards. Now the date and time are off by 5 years.
    After that, it tried to boot and I got the message about a disc needed to be checked. After it ran its course, windows didn't boot. I plugged the dvd rom back in with the xp disc in and got the 94 error code again. I let it run for 20 minutes of so and it didn't change. The dvd light flashes and you can hear it spin.
    Nov 2007
    North Central PA
    Well, after repeated failures, I finely took out the hd and reinstalled a previously made ghost image. Everything is working again. Now I just need to remember all of the changes that I have made since creating the image
  1. itx wont boot
    By plunderisley in forum General Hardware Discussion
    Last Post: 05-05-2008, 11:38 AM
  2. M2-ATX wont boot after a while of sitting
    By pirotlord in forum Power Supplies
    Last Post: 06-04-2007, 03:32 PM
  3. my computer wont boot to windows, says "Boot From CD :"
    By shrinkydinx in forum General Hardware Discussion
    Last Post: 07-18-2006, 01:45 PM
  4. Replies: 10
    Last Post: 04-17-2006, 06:23 PM
  5. car pc wont boot
    By paradoxni in forum General Hardware Discussion
    Last Post: 07-30-2004, 04:37 PM
