Results 11 to 20 of 23
Thread: Nexus 7 built in to double DIN enclosure. External DAC, USB drives, Auto ON / SLEEP
  1. #11
    Mar 2012
    Arezzo, Tuscany, Italy
    Thanks for the words about my car! Yeah I read about the 4C going to US!
    I will start my new project within days but with your feedback I might be changing something. I bought an Hifimediy Sabre DAC but it has no input. I agree, voice control is vital for car applications. I think I'll copy your setup even for the mic
    Didn't know why Play Store reports all my devices incompatible with dragon mobile assistant (nexus 7, galaxy nexus, motorola xoom and galaxy tab 7"), I have only compatibility for Dragon remote microphone. Maybe it is not available outside US, or it has not italian voice recognition. However, if google voice recognition works, better than nothing!
    EDIT: form the Nuance website:
    Q: I am residing outside the US. Will I be able to use the application?
    A: Dragon Mobile Assistant is currently only available in the US on Google Play.
    As we add additional languages and variants of English, we will include support for additional countries.
  2. #12
    Sep 2011
    nice write up, ill probably try and follow most of this to install a tablet in my mustang.
    I havnt been in my dash for nearly 2 years so will need to check and see how to wire everything together.
    Also I have no idea how ill get everything to fit, maybe ill try and learn how build a fiberglass panel
  3. #13
    Oct 2008
    Verry Nice install
    Did you use the nexus 7 2012 model or the 2013 model?
    Is there a rom for the 2013 model?
  4. #14
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Quote Originally Posted by Hind View Post
    Verry Nice install
    No. Timur closed development on USBROM with the 2012 model. So this will not work with a Nexus 7 2013 (no matter how many hours you put in...ugh).
  5. #15
    Oct 2013
    Your set up is awesome! And I want to do the same thing, but Iím a rookie, so youíll have to forgive my very basic questions.
    1/ To what do I connect the Carnetix CNX-P5V?
    2/ Where does the computer heat sink sit? On top of the N7 processor?
    3/ For switching the power supply on and off with the car, will this work as the 12V relay before the Carnetix CNX-P5V?
    http://www.radioshack.com/product/in...ductId=3020762
    4/ If Iím understanding you correctly, to power everything, you have to connect the Male USB end of the OTG Y-cable to a cigarette USB charger? That means thereís going to be a visible cable running from the cigarette USB charger to the N7? If thatís the case, it doesnít look very OEM. Is there some way to get around this, such as hard wiring the cable supplying the cigarette lighter to the Male USB end of the OTG Y-cable (therefore there would be no need for the cigarette lighter or the USB charger, then I could perhaps hide the USB OTG Y-cable under something).
    As I said, Iím a novice, and any detailed cook book-like instructions would be greatly appreciated. Thanks a million!
  6. #16
    Oct 2013
    Ion your set up is awesome! And I want to do the same thing for a non-Corvette, but Iím a rookie, so youíll have to forgive my very basic questions. I also posted this on mp3car.
  7. #17
    Mar 2011
    Awesome write up. I'm hoping to have a N7 before the year is out and making a headunit out of it for my Cobalt is on my todo list.
  8. #18
    Oct 2004
    Quote Originally Posted by Ion View Post
    Thanks. I just checked out your project thread. Very nice Alfo Romeo. I don't think I've ever seen one in person here in the US but we're supposed to get the 4C over here next year.
    I haven't had any issues with the mic and DAC so I'm not sure why others are. I'm using the Behringer UCA202 DAC with an Olympus ME-52W Noise canceling microphone. I use a 1/8" extension cable and a 1/8" to Mono RCA plug converter connected to the Left RCA input on the UCA202. The monitor switch is set to "OFF" so there will be no feedback. With this configuration, any voice app works incredibly well including Google's built in recognition. The App I'm primarily using is called Dragon Mobile Assistant.
    https://play.google.com/store/apps/d...uance.balerion
    The trick is just to mount the mic some place in the car where there isn't too much noise. My first location was on the A-Piller on the driver side near the dash and window as it was out of sight. This didn't work well because of proximity to air vent and also the window when open. Re-routing it to the middle of the trim above the windshield provided better results. Voice control is very helpful as the text and buttons on the Nexus are small and it can sometimes be hard to read in the direct sunlight.
    -Ion
    I haven't been able to get the my external mic to work through the left channel input of my UCA202. I'm running Timur's USBROM on a Nexus 7 (2012). Were there any settings that you changed in order to get this to work? It's picking up sound from the internal mic only. Thanks in advance.
  9. #19
    Dec 2014
    Thank you for the work you put into this project and write-up. I have been working on a similar project and found your resources to be quite useful. I picked up a Nexus 2012 but cannot find a download anywhere for USB ROM. It seems the creator took it offline and I cannot locate a mirror either. Do you still have an original download for it? Can it be posted online? I am happy to host a mirror for it for other working on similar projects. PM me if needed. Thank you!
  10. #20
    Mar 2012
    you can serach for AutoDroid, based on CM 11 and android 4.4.4 for the nexus 7 2012.
  1. Replies: 4
    Last Post: 06-16-2013, 04:28 PM
  2. App for auto pause/sleep??
    By DrLove in forum iPad Apps for the Car
    Last Post: 08-30-2011, 08:44 AM
  3. Auto On/Off Using Hibernate *and* Sleep?
    By Lumenii in forum Power Supplies
    Last Post: 09-01-2010, 12:27 PM
  4. Replies: 2
    Last Post: 10-06-2006, 01:37 PM
  5. FS: Hard Drives, External Enclosure
    By StratusPh34r in forum Classified Archive
    Last Post: 04-22-2005, 11:57 PM
