Results 1 to 4 of 4
Thread: Need Some Advise on a this Board Please: Asus P7H55-M LE
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I'm a laptop guy in my build so this ATX stuff is new to me... This is for my brother's proposed build.
    Here's the spec's:
    uATX Form Factor
    9.6 inch x 8.6 inch ( 24.4 cm x 22.9 cm )
    Recommended PS-300W
    Will an M4 power this board? (I think he said he is running a I5 on it)
    Will it fit in the Standard VOOM case?
    Will it fit with a CPU fan & if not, can it be run with just a heat sink assuming it will fit with just a heat sink?
    Would this older PC below perform well used mainly for SAT radio and FLAC music if the above does not work out?
    Motherboard : Zotac Gf9300-K-E
    Box : Mini-Box VOOM
    CPU : Intel Core 2 Duo LGA775
    Ram : 2GB
    Thanks!
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    that does depend on wich i5 proc he will be using , they do vary in power consumption quite a bit, and with the processor choice you will have depending on type , possibly different sized fans
    I am an amd guy , seen that with my pc's , I assume its the same deal with intel stuff
    after a quick google on the lower pc specs , I think it will do , be on the lower powered end but I think it may run just fine epending on os, frontend etc
    View my worklog here
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    That board will not fit in that voom case. That mainboard is a full size home PC and will draw more power than it's mini-itx brother. The M4 should have enough power but it might be closer to the higher end of it's limits. If you already have that older setup inside that case, I would go for that one. Just my 2 cents SNO
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Thanks guys, I'll let him know we should probably find something else.
  1. ASUS AT3IONT-I Deluxe board
    By xraymikek in forum General Hardware Discussion
    Last Post: 07-02-2013, 11:25 AM
  2. Replies: 3
    Last Post: 01-25-2007, 07:11 AM
  3. some advise
    By islandsound in forum Newbie
    Last Post: 02-08-2006, 03:51 PM
  4. advise on DSP
    By Vish_Janu in forum Car Audio
    Last Post: 08-22-2005, 04:16 AM
  5. Check out this small Case and Board from ASUS
    By dekodan in forum General Hardware Discussion
    Last Post: 08-30-2001, 12:18 AM
