Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 57
Thread: Some more questions
  1. #31
    Oct 2010
    Greece
    ok got some hours wasted today. i did everything i could think of . Even a dual boot installing windows 7 . Nothing .
    I cant get any signal on the dvi . i think this is a damaged port or maybe a wrong cable.
    I ll stop searching and start to looking for a pci card. If anyone in here got anything that can enter the old pci and send dual video then send me a pm.
    I ll start looking on ebay.
  2. #32
    Oct 2010
    Greece
    Ok. guys back to the first post again.
    I am looking for a usb gps to buy as my bluetooth is not going me anywhere ( it needs pairing and confirmation code every time ). So i wanted to ask if there are out there gps usb modules with the option of an external antenna. if not are you happy with these globalsat devices ? Do they have tmc too ?
    That was the first thing . The second one is that i am running out of free usbs . WHat do you suggest . A usb hub will do the work . Are there any other solutions .
  3. #33
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    This is the best GPS for the money! http://www.sureelectronics.net/goods.php?id=99 It has an external antenna and connect via bluetooth,serial or usb. SNO
  4. #34
    Oct 2010
    Greece
    nice one Sno . i wonder if it can connected and powered by the RS232 Interface. only thing to left is the shipping cost . i ll send them a question
  5. #35
    Nov 2009
    Keswick,On Canada
    I will try on serial later today to see if it also needs power SNO
  6. #36
    Oct 2010
    Greece
    Quote Originally Posted by SNOtwistR View Post
    Thats perfect SNO . I ll wait to see.
  7. #37
    Nov 2009
    Keswick,On Canada
    OK all the boards I have here at the moment, I have removed the serial port from the board. I can solder up one tonight but you can add 5v to the board if it needs it via the USB A socket pinout as they only populate the mini-usb port. it only draws 50ma SNO
  8. #38
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    I just wired the board to my 5v out on the psu and have it communicating over serial...that way its normally at least powered up.soldered it directly to the boards missing usb plug pins.
    Sent from my GT-N8020
  9. #39
    Nov 2009
    Keswick,On Canada
    Exactly what I was thinking
  10. #40
    Nov 2011
    I like as few connectors as possible.had too many problems in the past with crimps and loose pins...and at 50 ma why not
  1. CAN bus questions and more
    By Crooozin in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-22-2009, 02:21 PM
  2. M2 ATX questions
    By VonBillion in forum M2-ATX
    Last Post: 12-19-2009, 04:48 PM
  3. questions, quetions, questions...
    By [ULKER] in forum Newbie
    Last Post: 08-01-2006, 11:12 AM
  4. Few Questions
    By JustWaiting in forum General Hardware Discussion
    Last Post: 12-29-2005, 03:57 PM
  5. Questions about running cable, also powering questions
    By dudah85 in forum General Hardware Discussion
    Last Post: 05-31-2001, 10:36 AM
