Results 1 to 4 of 4
Thread: Using Computer Speaker system in Vehicle (A how to guide)
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I have been using my logitech x-540 5.1 speaker system in my truck for the past 2 years and am very happy with the results. It is powered via the vehicle power and using the 4 existing factory speakers. I prefer this setup for a couple of reasons. Designed for computer use, low cost and most of all the remote on/off and volume/bass control. I like this setup so much I had to find another set for my Motorhome project (A new Frontier). Found a set on kijiji used, for the same money I paid originally (I'm sure the seller was very happy). This method can be used on other speaker systems I just prefer this model. Anyhow here is how I do it.
    This it the sub box and remote
    I removed the panel on back, this is the existing 120v power supply
    This is the AMP guts
    I removed the sub speaker as well to remove power supply
    This is the 14.6v side we need to be concerned with I have circled the positive side (you can see the circuit board trace goes from wire to fuse)
    This is the backside showing the ground side (notice the bigger traces usually a good sign it the ground)
    Installed the new wires for DC
    Solder the new DC wires to where the original wire went to (polarity matters)
    Install rear panel back in place and added connectors for ease of install/removal
    Now usually this sub sits on a floor, The Motorhome has "shag" carpet and didn't want the bass getting absorbed by the carpet so I installed a piece of wood to simulate a solid floor. Makes for good bass
    Side view of sub speaker and reflector wood
    For power this is the best power supply money can buy and very reasonably priced for all it does DC-DC-USB sold in MP3Car store!
    Last step is to set your voltage output on the DC-DC-USB power supply. Just put your voltage in and click set and save.
    I hope this helps someone to get some good sound with volume control using existing factory speakers and not break the bank doing it. SNO
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I have that DC-DC converter in my project too, and I am very pleased with it. I like the ignition to turn it on and time delay to turn it off feature.
    Sent from my SCH-I535 using Tapatalk 2
    Nov 2009
    Keswick,On Canada
    Here is a short video showing the end result. Bear in mind this is done with a crappy recording device and playing through the original 1979 factory speakers. SNO
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    That's awesome, a sound system disguised at a V-8..... seriously though, for factory speakers in the MH, that sounds good!
  1. Powering my Computer in the Vehicle
    By jrbush82 in forum Power Supplies
    Last Post: 05-02-2009, 06:24 PM
  2. Computer Remote Start Guide (laptops too?)
    By Man Ace in forum Newbie
    Last Post: 03-30-2005, 08:40 PM
  3. Ultimate Car Computer Vehicle
    By Pegasus in forum General MP3Car Discussion
    Last Post: 01-21-2005, 05:26 AM
  4. Blaupunk M3-system + instalatin guide
    By huscvarna in forum General Hardware Discussion
    Last Post: 10-12-2003, 10:17 PM
  5. Suggestions for a computer speaker system....
    By stinkynathan in forum Off Topic
    Last Post: 01-18-2003, 06:44 PM
