Results 1 to 5 of 5
Thread: Advice on a first time build
    Newbie ProGEEK's Avatar
    Aug 2013
    Karori, New Zealand, New Zealand
    Hey Folks, I'm a new CarPC Enthusiast and I am wanting to get a couple of pointers and clear up a few things.
    I am planning on using the Bybyte BBX-1 Double Din Enclosure http://www.bybyte.com/bbx1.html, To do this I need to remove my Car's head unit (Which I barely use as it is useless)
    Now, As i am replacing the head unit, I am left with the question on how to power the 2x rear and 2x front speakers, I know I need an amp, but i'd rather not use a full size one, I've seen a couple of the small ones that can be installed in the car pc case which seems like a good fit, My questions are, is this all I need? And can anyone recommend some decent(ish) cheap amps and / or kits.
    Any help and / or recommended product links would be much appreciated.
    Newbie NOVAK's Avatar
    Oct 2009
    Sacramento, California
    Not to answer your question but what motherboard do you plan to use? Whatever you do, do NOT use and of the motherboards recommended on the BYBYTE website. I used the VIA NX15000 back in 2010 and it was slow as a snail and has all sorts of issues. I used the green colored amp sold on bybyte and it worked fine and fit in the blackbox.
    Aug 2013
    I went ahead with the E350N-WIN8 From Gigabyte, quite a decent little board
    Aug 2010
    Bahrain
    Good choice for the motherboard.
    As for your question, you'll need a M3-ATX power supply and a monitor (I have a used Lilliput EBY701 monitor for sale, PM if interested).
    As for the amp it really depends on what kind of car do you have and what kind of power you want, if your car doesn't have a stock AMP and you're happy with the sound quality/power then nearly any full sized AMP is sufficient. You'd need the installation kit for the AMP as well.
    Elsewhere
    Quote Originally Posted by alawadhi3000 View Post
    Before committing to the M3 (or any DC-DC PSU), I highly recommend comparing the power draw of your PC and peripherals against the output ratings of the M3-ATX. Based on what I see, the M3 is certainly suitable for the PC itself with a hard drive and such, but when you start adding additional USB devices that require power, you might overtax the 5v rail. Remember that AMD CPUs typically draw power from the 5v rail as well.
    As for a small amplifier. there are a couple for sale in the MP3Car.com store: 4ch X 30w RMS and 2ch X 25w RMS
    Bear in mind that these units require regulated power, which means drawing from the PC's PSU or a separate 12v regulator.
    How about the Wiki?
  1. ignore
    By Mad1 in forum General Hardware Discussion
    Last Post: 10-30-2011, 05:42 PM
  2. 1st time build proposed rig.
    By Matthew Rowland in forum Newbie - Proposed setup
    Last Post: 03-07-2011, 02:18 AM
  3. Advice for F-150 build
    By nitrobass24 in forum Newbie
    Last Post: 09-05-2009, 11:41 AM
  4. Replies: 0
    Last Post: 01-29-2009, 10:31 AM
  5. I will BUILD IT I MEAN IT THIS TIME
    By D M N in forum General MP3Car Discussion
    Last Post: 07-31-2005, 04:24 PM
