Results 1 to 3 of 3
Thread: M2-ATX and new intell 1150 mainboards
    Apr 2009
    Toronto, Canada
    Does anyone know for sure if the m2-ATX power supply will work with the newer intel socket 1150 mainboards? The reason I ask is that they have moved away from the P4 connector on the board, and are now using an 8pin power connector. The M2-ATX only has a P4 output. I know the M2-ATX's 20 pin connector will work in the 24 pin connector, just not so sure about that 8 pin connector. Thanks!
    May 2012
    Grandville, MI
    The 8 pin connector is the same as the P4 connector with 4 more pins. This is the CPU power adapter.
    I have a M3-ATX which has the 20 pin connector, a SATA power connector and an older style 4 pin HD connector.
    You can buy adapters to go from the 4 pin connector to the 4/8 pin connectors.
    I bought an 8pin to 8pin extension cable and took a 4 pin Y cable I had and combined the two. The 4 pin adapter has 2 grounds(black), 1 +5 (red) and 1 +12(yellow). The 8 pin connector has 4 +12 (yellow) and 4 ground(black). My manual says not hooking up the connector can cause the CPU to work erratically. If you are using a low power CPU and your power supply supplies a P4 you SHOULD be able to get by with just the 4 pin connector. It will only fit on your board in one way. Check your manual. My motherboard talked about 4 pins supported something like 65watt and lower CPU's and for higher you need the 8 pin connector.
    So just check out what your manual actually states about it. When all else fails it doesn't hurt to provide all 8. I also bought a 20-24 pin converter to allow me to use all 24 pins but I haven't tried to use it. My CPU is a 55watt I3 processor.
    Apr 2009
    Toronto, Canada
    Quote Originally Posted by redheadedrod View Post
    Thanks. I was able to verify with the mainboard manual that it would take the p4 using only half of the 8 pins. This is the maximus VI impact. The tdp on my processer is 55w, so it's good to go.
  1. FS Dell Insperion 1150 Laptop
    By Charles1 in forum Classified Archive
    Last Post: 08-30-2006, 12:57 AM
  2. FS: two Mainboards and DDR 400 SDRAM
    By TruckinMP3 in forum Classified Archive
    Last Post: 03-30-2006, 09:57 PM
  3. FS/FT: Dell Inspiron 1100/1150 (2 laptops)
    By fventura03 in forum Classified Archive
    Last Post: 09-28-2005, 11:44 PM
  4. mini-itx mainboards without audio??
    By mdaize in forum Newbie
    Last Post: 02-10-2005, 06:15 PM
  5. ECS mainboards?
    By Ryndel in forum General Hardware Discussion
    Last Post: 05-15-2002, 12:09 PM
