Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Powered USB hubs
  1. #11
    Sep 2010
    Just putting another option out their:
    This is what I use, however, I would google it to find a better price, fleabay seems to have the best price nowadays.
    http://www.startech.com/Cards-Adapte...Hub~ST7200USBM
    I like it because its constantly on - so I can charge my phone threw my mounted USB port, and Other things have constant power so I dont have to worry about it powering on properly. Had it about 2 years without an issue.
    I'm thinking about moving to this one day:
    http://www.startech.com/Cards-Adapte...ble~ST7300USBM
  2. #12
    Elsewhere
    Quote Originally Posted by trippah View Post
    I dont have a power supply (running laptop) so i need to power it from the car, but Ram USB Tough USB is a bit too expensive for a usb hub....
    I only have 3 ports to play with, and need to connect all these devices...
    2x2.5" hdd,
    webcam,
    video capture card,
    usb volume knob,
    bluetooth keyboard,
    wifi,
    touchscreen,
    odb2,
    gps,
    3g dongle,
    I have to ask why the hard drives would be USB instead of SATA or PATA.
    Internal drives would eliminate the need for two USB ports alone.
    How about the Wiki?
  3. #13
    Sep 2011
    I've modded several usb charger cigarette lighter adapters for use as a 5 volt source. The only problem I've had was when I was using a laptop that had a battery in it. It would back feed voltage through the usb port. I added a diode to solve that problem. I've also used some of the Anker Uspeed hubs that are 12 volt native.
    Works for me. YMMV. lol
  4. #14
    Dec 2007
    NY
    snotwistr, one more question...I think...did you get pig tails for this or did you solder directly to the leads? I can't find pig tails or a connector that will accept anything larger than a 22G wire, I need 20g for 1.5 amps. I generally would prefer not to go through the hastle of soldering to this because I don't have a solder gun w/ enough wattage to properly solder to a solid object like that...just wire to wire.
  5. #15
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I just solder to the ends, you don't need much heat these are very small the same size as a lm7805 regulator or you could crimp some connectors on with a good crimper. SNO
  1. 12v powered USB hubs
    By LancerAM in forum Product Suggestions for the Mp3Car Store
    Last Post: 07-31-2012, 11:22 PM
  2. Powered USB Hubs?
    By Booger in forum Power Supplies
    Last Post: 06-09-2007, 09:21 AM
  3. USB Hubs / Powered or not
    By Scafremon in forum General Hardware Discussion
    Last Post: 06-15-2006, 09:03 PM
  4. Powered USB hubs
    By 2000Jeep in forum Newbie
    Last Post: 05-30-2006, 11:30 PM
  5. ? about powered USB hubs
    By schapman43 in forum General Hardware Discussion
    Last Post: 07-16-2005, 04:38 PM
