Results 1 to 8 of 8
Thread: This might be fun....
    VegasGuy's Avatar
    May 2009
    Las Vegas
    http://www.tomshardware.com/news/int...ess,26597.html
    Key takeaways:
    • Has 4GB of Flash memory already installed.
    • VGA Output
    • 3.5 Headphone output
    • USB 2.0/3.0 ports outside
    • Accepts 12 -19V power
    Fun fact - Windows 8 Embedded Industry Pro minimum install is 1-2 GB. Full install is less than 4GB.
    Throw 2GB of RAM and a nice little SSD, add a mini-PCI-E wifi card (antenna ports are already there), and you could have one very nice little box I think.
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Wonder on the pricing?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Considering the celeron NUC is only $150, maybe under $100?
    Tidder
    Try RevFE
    Nov 2011
    Good pricing!! Now i want one to play with
    Sep 2012
    Germany - Munich
    "a single-core Atom E3815 processor clocked at 1.46 GHz"
    i think the chip has not enough speed for a carpc.
    Nov 2011
    You might get a basic setup...music radio/dab and nav
    VegasGuy's Avatar
    May 2009
    Las Vegas
    The new Bay Trail processors are pretty good. MUCH better than the older ATOM chips. I've got a Miix 2 tablet with the 1.33 Bay Trail quad-core and it is very nice. Keeping in mind that very few things you do on a car require (or are programmed for) multiple cores, it might work better than you'd expect. TDP on this chip is 5W, so this really is a low-power/low heat setup. You could probably tuck this behind/under the dash and have no problems at all. But I agree that price will be a deciding factor.
    Jun 2014
    Personally looking at the ecs liva pc small bay trail pc 5v 3a power usage. Wondering on performance and if its possible to add rear screens via USB to hdmi adapters for people sitting in the back seat.
    Sent from my TF600T using Tapatalk
