Results 1 to 6 of 6
Thread: Cig lighter adapter to power PC?
    Jan 2003
    Is it safe to use a 12VDC Cig lighter adapter to power the PSU? The PSU takes 12V @ ~5amps. So if I get a 12V cig lighter adapter rated for 10amps and change the fuse to 5amps, would it be safe?
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    As long as it is regulated, yes. Sounds like you have one of those power supplies which passes the 12v straight through. An unregulated (straight through) cig lighter cable will give about 14v when the engine is running.
    Rob
    Hosting Guru
    Oct 2001
    Atlanta, GA
    dunno about you but my car passes a nice 12v.... guess it depends on the auality of the aslternator
    -- WireSix, Inc. --
    MP3Car Lives Here!
    Apr 2000
    Bedfordshire, UK
    When did you measure it? Was the engine revving or at tickover?
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    The batterty has a nominal voltage of 12vdc, but alternators have a nominal output of 14vdc afaik.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Alternators HAVE to supply a higher voltage to charge the battery...so your battery will give about 12.5 but the alternator has to give 13.5 to 14ish...otherwise the battery will constantly be draining.
    (whatever supplies the higher voltage does the work)
    The important question is do you trust the item you have to work directly off the 12-14vdc in your car.
    The safe bet is to get a 12v regulator (but for 2 amps or more they get expensive).
    However many people on this board have run items directly off the car power.
    How lucky do you feel
