Results 1 to 4 of 4
Thread: Quick release case mounts?
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Good morning all,
    I'm looking for a quick release case mounts solution to enable me to remove the VOOMPC2 case with ease.
    I have wifi which works well but sometimes need the PC inside to do work.
    I hoping for some type of elegant looking bung/cap that locks into position and squeezes to release, or similar if you get my drift .
    Cheers
    Sent from my LT30p using Tapatalk
    Vauxhall Astra SXi Car PC installed.
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I just mount mine with 2 screws, but I could get threaded inserts and use thumbscrews, or I could put bolts up through the carpeted mounting board, and use wing nuts.
    Mar 2005
    Norfolk UK
    Wing nuts don't fit as there isn't enough room to spin them. I currently have the coach bolts coming through the wooden base with a securing nut, then the voom case being secured with another nut....
    Cheers,
    Dave
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    I use zip ties..quick cut and its out but i have a raised mounting plate that matches the voom case under my front seat
  1. Quick Release / Docking station for EEE PC
    By kwchan in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-06-2008, 08:31 AM
  2. quick release power to computer?
    By theheel in forum General Hardware Discussion
    Last Post: 03-15-2005, 10:37 AM
  3. VGA screen quick release?
    By Rafster in forum LCD/Display
    Last Post: 02-01-2005, 09:08 PM
  4. Quick release components
    By chuckster in forum General Hardware Discussion
    Last Post: 10-06-2004, 10:52 AM
  5. Shock mounts for case or HDD?
    By gork in forum General Hardware Discussion
    Last Post: 08-06-2003, 10:31 PM
