Results 1 to 6 of 6
Thread: Bondo...
    Constant Bitrate Seabass's Avatar
    May 2003
    Bondo...
    Hey everyone, ok I bought this stuff at lowes today and i thought it was the right stuff but now im not so sure. Im gonna be using this for a subwoofer box so please tell me if its the right stuff. Ok on the bottle it said All-Purpose Fiberglass Resin, so i thought that that was the stuff. But now i just got back from work and on the top in way smaller writing it says "bondo-Home Solutions". Is this "Bondo" or is the fiberglass resin that I thought it was ? thanks everyone, Seabass
    Jan 2003
    Ruston, LA
    It's Bondo *BRAND* Fiberglass Resin
    Bondo is only a brand, the stuff commonly referred to as "bondo" is plastic body filler, kind of like saying like I'm going to the store to get a coke and you come back with an RC cola or something
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    May 2003
    sweet cuz i was gonna be ****ed cuz i spent $25 on this Thnx, and ummmm i read somewhere that if you want a very smooth finish(and shiny) kinda like a piano then you would only use resin(3-5 layers) combined with a color pigment(the color you want it to be) and then sand it down A LOT and wax it if you prefer...is that the way they usually do it....?
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    the search button is really nice I hear
    Fiberglassing Tips?
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    Low Bitrate stkdidy ntshidy's Avatar
    Jul 2003
    california
    the best way to get a nice glossy finish is the following...
    make a frame of fg carpet or fabric that is as smooth as possible to begin with. stretch it as tight as you can over subwoofer rings (u did make and use those didn't you?). apply the resin, apply another layer of fg fabric, apply resin...etc util you have at least 1/4-1/2in of fg. let it dry. sand the hell out it, then apply a layer of bondo (the original stuff). smooth this out completely and let it dry. sand the hell out of that. when its as smooth as you can get it, apply a primer like you would when staining wood, only for this type of surface. airbrush painting is preferred for coloration, but anything you can put on nice and smooth is ok. let it dry, apply a glossy finish coating, and let that dry...easy enough
    NOTE: 1/4 in of fg is PLENTY!!! 1/3 is overkill for sure, and 1/2 is only for the weak at heart that want their fg to be as strong as possible
    most people use less than 10 layers, often 5-6 which is mor like 1/8in, but i recommend going the extra mile and putting 12 layers or so on
    2005 Mustang GT:
    12w7...arc audio kar1000.2t...jl 300/4 pushng focal 165k2p...pioneer premier deh-880prs...tm-701l...audiocontrol eqs
    want: my stereo actually IN the car
    Jun 2003
    Memphis - TN
    If you want a really prefoessionaly looking sub box, some people use truck bed spray liner and spray the box. It gives it a hard textured look, its not smooth and shiny, but looks really nice.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
