Results 11 to 20 of 30
Thread: Windows 95-98 networking + Windows machine booting in dos mode every time...
  1. #11
    Jul 2001
    Post
    Yeah, well, I tried NetBEUI with no luck, Each computer can see its self, but they can't see each other...
    BTW, I'm using a BNC cable, not a crossover, does this make any difference??
  2. #12
    Jun 2000
    Salt Lake City, UT, USA
    Post
    Are both ends terminated with 50ohm resistors? I've dealt very little with BNC cable but I know that much!
    1983 BMW 733i
    Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
    Gathering parts for carplayer v2.0!
  3. #13
    May 2001
    Australia
    Post
    The first thing to do is to make sure that file and printer sharing is enabled on both machines and that each has at least one drive shared. This is a common fault in some versions of windows 95-98. You may want to use TCP/IP instead of netBEUI this will at least allow you to ping the other machine to see if the network hardware is operating. use an address of 192.168.1.1 for one machine and 192.168.1.2 for the other and a subnet mask of 255.255.255.0 on both. I won't go into a detailed explanation of why those. The 192.168.*.* address range is reserved for intranet use. Most people here will know this allready so it's for your information Skinnyboy.
  4. #14
    Jul 2001
    Post
    okay, thanx...
    I'll try this tomorrow, and yes, I do have the cable terminated at both ends..
  5. #15
    Jun 2001
    Boise, ID (USA)
    Post
    I have have used IPX/SPX protocal to network win 95 & win 98 together with no trouble at all! One thing I did have to do was set the frametype to ethernet 802.2 (dont know why this works???)
    mike
    1999 voyager pontoon boat
    (soon to be computerized)
  6. #16
    May 2001
    Australia
    Post
    I dont wan't to got into an arguement about protocols. I believe Skinnyboys problem has nothing to do with the protocol. It's more likely that the problem is due to either hardware or a sharing/netbios problem. I suggested TCP/IP so that we can eliminate the possibility of a hardware fault by pinging acroos the network. From what I've seen netBEUI is actually the fastest protocol. However netBEUI can't be routed wich makes it fairly useless for anything other than a small LAN.
  7. #17
    Low Bitrate radioman193's Avatar
    May 2001
    Dansville NEW YORK
    Angry
    EVERY THING THIS JIRK IS TOLD HIS REPLY IS" I TRYED THAT AND " I HOPE SOME DAY HE REALY NEEDS HELP AND CAN'T GET IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!
    YOU DUMB SH#@!
    GET A LIFE CHILD.
    Sorry Can't be nice nomore.
    [ 08-12-2001: Message edited by: radioman193 ]
  8. #18
    Jul 2001
    Post
    Is it possible that my network adapter is faulty?? Or is the fact that the computer can see its self a "sign" that the card is working??
  9. #19
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    Post
    I've gotten caught many times with bad terminators. You may want to replace both of them before you try anything more drastic.
  10. #20
    Jul 2001
    Post
    I think you may be right about the terminators... I have had great trouble getting other networks to work with these 2 terminators... It could also be the cable..
