Results 1 to 7 of 7
Thread: Usb 3.0 and cold weather issue.
    Dec 2007
    NY
    I have the zotac ad10 plus, when it gets below 54' I get hardware error "Reneses usb 3.0 eXtensible Host Controller - 0096 (Microsoft)". And it won't work until the computer warms up...if it warms up enough...and I reboot the system. This will be even worse because I plan on putting in a SSD disk which won't produce as much heat as the regular disk, so there won't be any warming up pretty much. I'm thinking of getting the zotac ci or ca 320 and I'm wondering if I'll run into the same issue. Or is this simly a common issue with usb 3.0 controllers?
    Dec 2007
    NY
    No answer? Nobody has experienced this at all? Ok, then what is the hardware or spec that I should look at to be different so I don't run into this issue again if anyone knows?
    Oct 2010
    Greece
    man sorry i am not into that . but i was thinking that a way to get trough this is to preheat the chipset that controls the usbs. maybe something like this for a few seconds could do the job
    Vw Sharan 2007 1.9tdi || Exide 100Ah
    Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
    Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
    Powered by M2 atx
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Not sure on the mainboard specs but for car environment you should look at getting an industrial type mainboard... jetway http://www.jetwayipc.com/ or http://www.logicsupply.com/components/motherboards/ the difference will be in the components used that would allow lower operating temps. If you buy just a regular "house type" pc they would not expect your house to be below freezing temps. It is hovering around 0c here and my pc fires right up if it does get below -20 it will need to warm up abit before it starts. I should also mention I have ssd for os and WD black for music and I use those heating pad under that mechanical drive but I only need to run it for like 2 mins and the drive is up to temp running fine. Good luck SNO
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I second Jetway. Mine is an industrial rated board and low power too. I have a 35 watt I7 on it so its fast enough. 2nd winter without issue so far. Helps I rarely see freezing weather.
    Dec 2007
    NY
    Ok, thanks all.
    @happy_feet, having that in my trunk would scare me. That seems like a sure shot fire starter, on top of a guaranteed component melter.
    Oct 2010
    Greece
    Quote Originally Posted by Champak View Post
    Ok, thanks all.
    I didnt thought of this man . you are right it is a bit scary.
    Powered by M2 atx
  1. Cold weather
    By blaube in forum Newbie
    Last Post: 05-05-2010, 02:35 AM
  2. Cold Weather! To do or Not to do!
    By Shaazzaamm34 in forum General MP3Car Discussion
    Last Post: 12-16-2006, 01:20 AM
  3. LCD vs cold weather
    By Nomader in forum LCD/Display
    Last Post: 11-06-2006, 03:33 PM
  4. Carputer and cold weather... very cold!
    By Topper in forum General MP3Car Discussion
    Last Post: 07-14-2005, 08:41 PM
  5. cold weather
    By blaster in forum General Hardware Discussion
    Last Post: 12-11-2003, 06:12 PM
