Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Computer in Car? Let's reverse it..
    Constant Bitrate captain_jim1's Avatar
    Nov 2002
    New Jersey
    So, I was thinking .. why not take some car components and put them in the computer. I took an old Panasonic HU that I had and ran the power lines into the 12v lead on a Molex Connector .. and the ground into the ground on the same connector -- tada -- Head Unit comes alive!
    I can't see any danger in this and the geek factor is way high. Right now I have 2 Kenwood speakers wired up to it, but am thinking about making some sort of an adaptor that can plug into the sound card.
    I also want to now mold this into the case. It requires cutting the 5 1/4" spots a little wider, but shouldn't be hard. Will look killer at night.
    Watcha guys think?
    -Brad
    83 mp320i 285k
    PS. Looks like I caught the HU in a binary mood (18 for all you bums out there).
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    you know what would be super pimp fiber glass some speaker boxes that mounted on the side. Rig up a speedo to your cpu so you can see how fast you are runnin or at least rig one one up to your network/modem. Some flames on the side. Oh yeah!!!
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    I think you're maxing out the 12 rail pretty quick
    FLAC Mastero's Avatar
    Aug 2001
    India
    WOW! What an amazing idea !
    My friend if you connect your Head unit to the PC power supply on the 12 volt line you will never know when your Mobo shall go to the grave as the HU pull far more power and your PC PSU wont supply thus killing the pc PSu and the Mobo.
    SO I SUGGEST DONT DO IT.
    Mastero
    Jul 2000
    Ottawa, Canada
    i was thinking of doing the same thing, but i didn't think my PS could handel it..
    your powersupply looks pretty big but i hope your cranking some huge amps on the 12v rail
    say 10 amps drain on the 12v = 120 Watts
    how big is your PS, and have you pushed the volume all the way yet?
    [SIZE=1]'91 Nissan Stanza
    [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
    Car Totaled and i bought a 20G mp3 player
    http://machs-fuel.tk
    a DIY video projector page
    Nov 2002
    New Jersey
    It's a 300W PSU .. does this help? I played with all the settings and never noticed a lick of difference..
    -Brad
    83 mp320i 285k
    -Brad
    83 mp320i
    99 mp323i
    _________
    7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    The HU's are designed to receive 30amps from the car battery.
    Mastero
    do you have any idea what you're talking about?
    a head unit it designed to draw at the very most 10 amps (thats the fuse rating). in all reality it draws more like 4 or 5 at full volume providing it has a built in amp for speakers. Even at that i think is too high, someone want to test it and back me up? My entire computer setup in the old car drew 5 amps when running with an inverter to an amd k62 450 with a hd, dvdrom and 128 ram on all in one board with expansion cards.
    Brad i think you'll be ok, just keep a monitor open to watch the voltage. my mobo has a tool to monitor that and temps from windows. have fun
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    ha 30 amps??? in my volkswagen forum someone said "the thicker the wire, the higher the resistance"..and I thought that was a bad one
    HUs do only draw at max 10A, did you ever see a fuse in the back of an HU? But I would be careful, I dont think PSus put out too muhc 12v forward.
    Mine needs to be updated.
    Maximum Bitrate GuRuGoD's Avatar
    Jun 2002
    Omaha, Nebraska
    Thinking about this logically:
    My deck has 52W max output on each of its 4 chanels, thats 208W max speaker output (I will ignore any power used by the deck itself to keep it simple).
    208W/12V => 17.3A
    Remember this estimate is based on newer decks (the one in the pic looked older and prolly doesnt have the smae power output). But even still, most 300W PSU's are only rated for 12-14A on the +12V rail TOTAL. I will have to side with Mastero and Jol on this one. But to be sure, whip out your multimeter and see exactly what the desk is pulling on the 12v.
    90% Done
    60W DC-DC & shutdown controller
    Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
    Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
    All in a shiny White 2000 V6 Mustang
    Click here to visit my NEW PhotoAlbum
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    I saw this once very long time ago at a lan party. A guy there had rigged up one of them MP3 players with a flashy screen it looked freaking kicking rad at night. I dunno how he got the mp3s into the radio but it was on the front panel of the pc. He mounted it on one of them Antec Server cases. The damn thing was awesome.
