Results 1 to 3 of 3
Thread: Zotac CI320 power question
    Mar 2011
    Hey all,
    After purchasing the CI320, I saw that the power pack pushes 19volts. I did google and search this forum but havn't found the answer. Are anyone running this in your car? If so, how are you guys powering this unit? I have the M2-ATX-HD from my prior Carpc project I was planning on using.
    Thanks!
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    You need the Carnetix p1900 unit. http://store.mp3car.com/collections/...dc-regulator-2 That will be the easiest and best solution for you. Plus you can get 12v regulated for monitor and also add the 5v add-on and power your 5v stuff all from one box. Good luck SNO
    Mar 2011
    Thanks sno for the link and info! I must have missed the specs on that unit.
    Off topic for other users who want to use Zotac for carpc application. I took the unit apart and found that there is a PW switch pins on the board but without the pins. I also tested it and it does work. If you have some basic soldering skills, you can add the pins.
  1. Zotac CI320 Nano mini review...
    By VegasGuy in forum General Hardware Discussion
    Last Post: 01-02-2015, 10:06 AM
  2. P1900 to power ZOTAC IONITX-T-U and 7" Element LCD
    By bebopblues in forum CNX-P1900
    Last Post: 06-10-2012, 01:50 PM
  3. My Zotac Ion Question
    By InsaneQc in forum Newbie
    Last Post: 10-26-2010, 02:52 PM
  4. Zotac ION A w/M4 ATX
    By tlturner in forum M4-ATX
    Last Post: 11-25-2009, 11:24 AM
  5. Power Button Question for Zotac Users
    By BlueGhost in forum General Hardware Discussion
    Last Post: 09-09-2009, 12:14 PM
