Results 1 to 4 of 4
Thread: [REQ][INFO] Found this 7Inch PC. :)
    May 2010
    Question [REQ][INFO] Found this 7Inch PC. :)
    Hello,
    So I was given the following compact pc, wondering if I can use this as "CARPUTER Unit".
    And what will I need to get this running properly. Here are the specs I found on it..
    7 inch Touch Display.
    CPU: Intel Celeron 1.83GHz - N2930
    M-Board: Intel ATOM E3800/Intel Celeron N2930/J1900
    Memory: 2 Gb (expandable)
    HDD Size: 16Gb Flash drive - non removable (from what I can tell)
    OS: Windows 7 Embedded Standard.
    Inputs/Outputs:
    1 x line-out
    2 x USB (1x USB 3.0)
    2 x LAN (Dual Intel 82574L Gigabit Ethernet Controller)
    2 x Com Ports (not sure why needed)
    1 x USB Touchscreen / PCAP 7200 Series
    1 x Intel Display Audio + Realtek HD Audio
    POWER:
    1 x [ - / + FG ] DC 9~36v
    1 x SWITCH [ - / + ]
    I would really like to get this installed in my car as a project. Not to worried about the fabrication side just yet. I want to make sure I can get this working properly. My main concern is the AUTO On/Off . Will I need an inverter or special device for the unit to auto power up and power off.
    I attached some photos of the unit.
    Constant Bitrate Project07MACry's Avatar
    Aug 2009
    BK, NY
    Nice looking unit! Two things:
    1) Is there a brand name? I'd like to see where this came from, and see if it comes in any other specs...
    2) Please send (or PM) me a pic of the power button/power connection. Based on its design, it probably may require some disassembling/reassembling.
    All systems are a go...
    Currently in "tweaking" mode.
    The Worklog
    Sep 2012
    Germany - Munich
    is there a link to this unit?
    how is the display brightness by sunshine in the car?
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    There's a shortage of bezel space in the world. Because this company is hogging it all.
    Seriously though, that thing is kinda cool (depending on CPU).
    EDIT: Is the "SW" port a place to connect a power switch? If so, that might be the key to automatic power on/off with an automotive PSU.
  1. Looking for a 6-7inch screen
    By bigguy in forum LCD/Display
    Last Post: 10-10-2009, 10:28 PM
  2. found a HSU sub, not a lot of info, any thoughts?
    By damarble in forum Car Audio
    Last Post: 08-09-2006, 10:18 PM
  3. 7inch lcd
    By mjg7876 in forum LCD/Display
    Last Post: 12-06-2004, 08:53 PM
  4. File Info / Movie Info
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 04:42 PM
  5. Where to get my 7inch VGA LCD
    By orangewhip in forum LCD/Display
    Last Post: 06-13-2003, 12:51 AM
Tags for this Thread
