Results 1 to 2 of 2
Thread: Powered USB Hub?
    Maximum Bitrate Skippman's Avatar
    Mar 2002
    St. Louis, MO
    Powered USB Hub?
    I'm looking to add a powered USB hub to my Android based head unit. I have a WAP I'd like to be able to charge while driving as well as possibly run an external hard drive. I've seen the CNX-P5USB but wasn't sure if there was a less expensive option available.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I am sure you can use any powered hub and use a 12v to 5v regulator, I personally use the murata oki78sr regulator. http://power.murata.com/en/oki-78sr-5-1-5-w36-c.html They work great and have no heat issues. The other option I have is to use the Ram mount hub http://www.rammount.com/part/RAM-234-HUB1U but they are expensive as well but include an ignition on wire and a shut down timer delay. Good luck SNO
  1. self powered or bus powered for USB wifi adapter
    By jagsnag in forum Wireless Communications
    Last Post: 07-28-2005, 07:49 PM
  2. Best Bet USB Hubs Powered and Non Powered
    By lostreception in forum General Hardware Discussion
    Last Post: 06-19-2005, 05:51 PM
  3. Powered USB Hub
    By James141 in forum General Hardware Discussion
    Last Post: 03-10-2005, 05:18 AM
  4. What's powered by -5V?
    By Gutter in forum Power Supplies
    Last Post: 06-22-2004, 09:32 PM
  5. USB powered dvd
    By DJKhan85 in forum General Hardware Discussion
    Last Post: 06-15-2004, 12:56 PM
