You can sheil your case but you probably won't need to. You defiantly want good airflow in your system. one input and one output fan will get rid of alot of the heat. As for leaving the fans on all fo the time, it might eventually run down your battery, it may take days for it to happen but, it eventually will.
LinkBack URL
About LinkBacks
Might I suggest you take a look at my setup
