Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Multi-In, Multi-Out Switch Needed
  1. #21
    Constant Bitrate captain_jim1's Avatar
    Nov 2002
    New Jersey
    We're getting off topic here. We need to help find Brad his 4-pole double throw switch hehe
    I'm still looking ... but not finding....
    -Brad
    83 mp320i 285k
  2. #22
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    http://dkc3.digikey.com/pdf/T032/0834-0842.pdf
    Page 2, part number CKN1038-ND for example.
    There are loads of the things, I counted at least ten in that doc. Don't know why you are having so much trouble finding them.
    Rob
  3. #23
    Nov 2002
    New Jersey
    Thanks Rob! I can't understand these digikey sheets when I read them. I guess 4PDT was what I should have been looking for. 4-Pole Double Throw .. makes sense...
    Thanks again Rob ... the reasons we have these message forums is to enlighten the un-enlightened...
    -Brad
    83 mp320i 285k
  4. #24
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Quote Originally Posted by Rob Withey
    Yep, you can do that. That's basically what I did with mine, except that I tapped into the fm radio lines before the audio processor (so volume, balance and faders still work).
    Hmm, I have an old ProPlus CD headunit that I was going to ebay.
    It doesn't have any CD changer inputs, but the reason i swapped it out is the antenna remote line is only kicking out 9v, so it wouldn't fire the antenna, or the relay I use to power up the inverter.
    Might open that up, and have a dabble with it, maybe even have a go at boosting the antenna voltage too, and see if I can flog it modified to work with a carPC
    4x4 in a turbo stylee.
  5. #25
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    Rob
    How is that going to work? The switch only has two positions.
    *EDIT*
    OK I thought you had 4 sources. It does work.
  6. #26
    Nov 2002
    New Jersey
    Got the switch today so I went to Radio Shack, picked up my 12 RCA connectors and some wire and got to work!
    They all work great (except for 1 loose connection). Can't wait to get my carputer up and running so I can use this bad boy.. sure beats my FM Modulator.. volume doesn't get kicked back and when i swap between computer and headunit, they sound identical in quality and volume.
    In case anyone wants it, here's the diagram I made to visualize everything. Black wires are the audio signals and the colors are the grounds.
    Keep in mind I am not using the headunit's speaker wires, but rather all my speakers are powered by 2 amps .. which is what allows this to work
    -Brad
    83 mp320i 285l
  7. #27
    Jan 2003
    Ruston, LA
    glad you got all this resolved
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  8. #28
    Nov 2002
    New Jersey
    Thanks for helping!
    -Brad
    83 mp320i 285k
