Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Multi-In, Multi-Out Switch Needed
    Constant Bitrate captain_jim1's Avatar
    Nov 2002
    New Jersey
    My FM Modulator sucks! It does a decent job as FM Modulation goes, but that still isn't good enough. I really like my HU so buying a new one (with AUX IN) does not sound like a plan to me.
    Since I'm not using my stereo internal amp, but rather using 2 amps (one for front, one for back) I thought maybe there is a switch out there that would allow me to simply choose my source.
    http://www.stevieg.org/d.php/mr2carpc/build.html
    I saw this guy doing the same thing I want to do (although with 1 amp) and wondered where I could get a switch similar to him.
    I need it to take 8 inputs and have 4 outputs.
    Anyone know of anything like this? Thanks in adavnce!
    -Brad
    83 mp320i 285k
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    4-pole changover or 4-pole double throw is what you are after:
    http://www.maplin.co.uk/products/mod...343&Products=1
    Rob
    Nov 2002
    New Jersey
    So they make an 8 pole version? I ask because I started thinking .. I need double the inputs and outputs.... with every RCA cable there is the signal and a GROUND.. argh!
    Since there's 2 RCAs to each amp (4 wires), and I have 2 amps (so 8 wires) and I need to switch between Signal A and Signal B (16 wires) .... I need to then output all 4 RCAs (2 to each amp .. 8 wires).. So I need an 8-pole changeover.
    Lets see what I can find...
    Thanks!
    -Brad
    83 mp320i 285k
    -Brad
    83 mp320i
    99 mp323i
    _________
    7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
    Apr 2000
    Bedfordshire, UK
    Just tie all the grounds together. I don't think you need to switch the grounds, only the signals, so 4 pole would be good enough. I only switch signals in my headunit mod to add an aux-in:
    Aux-in mod
    Rob
    Nov 2002
    New Jersey
    Putting all the grounds together still leaves me with 5 signals .. the 4 audio signals and the ground. Maybe I should find a 5-pole throw?
    -Brad
    83 mp320i 285k
    -Brad
    83 mp320i
    99 mp323i
    _________
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    You tie the grounds together, and be fine with a four-pole. Me I'd get tvo four-pole instead
    Nov 2002
    New Jersey
    I see what you're saying .. I think .. I can tie all the grounds together and there'll be no need to send them into the switch....
    -Brad
    83 mp320i 285k
    -Brad
    83 mp320i
    99 mp323i
    _________
    Apr 2000
    Bedfordshire, UK
    Exactly.
    Nov 2002
    New Jersey
    Hmm .. Maplin is a UK company -- I can't seem to "checkout" and have the switch mailed to the US .. where else can I find this gizmo? Radioshack sucked and didn't have any...
    -Brad
    83 mp320i 285k
    -Brad
    83 mp320i
    99 mp323i
    _________
    Apr 2000
    Bedfordshire, UK
    Digikey?
