Results 1 to 10 of 15
Thread: New user- Starting project have some q..
    Aug 2003
    Found this site about a week ago and have been searching all weekend. I would like to try my 1st carpc install but have a few questions. 1st the car that this is going into is a 2003 altima non-bose. HU is a pioneer premier 7400, I have a 4 channel amp powering interior speakers, and a 2 channel powering 2 12"s. I have a sony laptop I cant remember the model number but I believe its a Duron 733, 20 gig, and DVD player. Heres the funny part the screen is cracked and I WAS looking for a replacement to swap in but then this idea hit me. If I wire the audio from the laptop to the aux port in my HU, and then buy a touchscreen like a DS700YYV to control with using the serial port and a vga cable, and then use a power inverter for the laptop and the LCD. By doing this I can use my laptop which is perfectly fine aside from a cracked screen, and just buy the screen and aux connector. Would this work? Would it sound good? Also any suggestions to make it sound better?
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    it should work as long as its a vga screen. You might have to hit the function+f5 key everytime you want it to switch.. I don't remember if it'll remember to use your vga out or not.
    '98 Explorer Sport
    80% done
    Aug 2003
    Ok thanks, I was also thinking I should probably use a usb M audio sonica for sound, so that It sounds decent. For power should use a inverter for the power going from the power adaptor to the inverter than to the battery or is there a better way?
    Low Bitrate lazarus's Avatar
    Aug 2003
    Leeds uk
    This is pretty much howmy car pc is set up (with out the extra amps etc). PIII 650 laptop with a busted display, hooked to a 12.1" TFT (touch screen kit turned up today so that has now been installed). it is powered by various DC-DC converters, a car laptop adapter that steps 12v upto various other voltages (about 22v i think) runs the laptop. and a step down converter that does 12v to about 2.5v, as the added advantage of regulating the voltage as well so i can run the LCD in the car with out blowing the controller board when the engine is running
    Aug 2003
    Could you specify the exact power specifications because I think I would like to avoid the blowing out the controller car when the engine is running like you are talkin about.
    Aug 2003
    Leeds uk
    basicly if the car is running then the aternator is trying to charge the car battery, this causes the voltage available with in the car to be above 12 volts. most electronic equipment is very sensitive to voltages so a few volts above what is recomended by the manufacturer can over stress the components and cause them to fail. this is very much the case with LCD monitors. so if you monitor runs on 12v it should be fine hooked straight to the battery if the engine isnt running, but once you start the car the voltage jumps up to around 14-15v and this is too much for most 12v displays, so you need a power regulator to keep the voltage supplied to the display at 12v (i learned this the hard way and blew an LCD controller board).
    the lap top on the other hand is probably a different story, as it will probably need more than 12v (mine needs 19v @ 3.2amp). personaly i use an in car lap top adapter to run it, that steps 12v upto various higher voltages (including 19v). got it from maplin.co.uk and it cost about £20.
    just make sure you voltages stay at the value you need and dont fluctuate and you'll be fine
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    you can probably get a car "cigarrette" lighter plug powre supply. I just did this for a fellow VW driver. We bought a female cigarrette plug and that worked just fine. USB sound, vga screen, touch, your good to go
    Ofcourse you'll have to find a creative way to mount it.
    Mine needs to be updated.
    Aug 2003
    Leeds uk
    Quote Originally Posted by samc
    this is the form that mine take. just use a 3 way splitter for the cigarrette lighter socket.
    riased the floor of the passenger footwell by about 3" so it all lives under there
    Aug 2003
    O that wont be hard to mount. Strangely they place a cigarrette lighter in the center console compartment. I can probably use that one. Thanks for the replys do you know anywhere I can get one or any particular good model?
    Aug 2003
    Leeds uk
    Quote Originally Posted by lazarus
    both mine came from maplin, though they seem to have stopped selling the 12v@2amp step down converter.
    You could take the route that GingerPrince did and build your own 12v regulator, the link to his site is in his sig. the scematic is at the bottom of the page
