Results 1 to 3 of 3
Thread: sony CDX-M700R connecting manual help
    Aug 2003
    Hello all. I have a sony cdx-m700r car sterio.
    my problem is that I have lost my manual for connecting the wires.
    sinse I changed car, i now have to put in the code everytime i use it :\
    isen`t it a memory wire or something that will memorize the code so I don`t have to type it in everytime ?
    so my question is :
    is there anyone that could tell me where all the wires should be ?
    in case the wires is differents I will tell you color of mine.
    Red = power
    blue = dont now
    black = earth
    light blue = amp filter
    blue with a white stripe = to an extra mobile or something
    Yellow = dont now
    orange with a white stripe = to an antenna
    I hope anyone can help me here
    I`m tired of type the code all the time.
    thanx
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    Check your PM
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by hunter
    Red = power
    blue = dont now
    black = earth
    Yellow = dont now
    thanx
    Some are pretty standard
    Red=Switched Power (ie only on when key is turned in ignition)
    Black= Earth/Ground
    Yellow=Continous 12V (this is probably the one you need)
    Orange=Antenna or other switched device
    HTH
