Results 1 to 10 of 15
Thread: A heatsink case for small PC (like a power amp style)
    Newbie phoTToniq's Avatar
    Mar 2003
    London
    Hi guys - have any of you made your PC's with a case that acts as a heatsink? I have only just started looking but have found this so far:
    http://www.lincolnbinns.com/e-case.htm
    P.
    Jul 2000
    Ottawa, Canada
    why don't you gut an Amp, you could probably find a blow one at a local radio shop.
    if you had a mother board small enough, or an amp big enough...
    hight would be the biggest problem i think, but it would look cool.. my amp is a freaking beast. could probably fit a full ATX board in there..
    [SIZE=1]'91 Nissan Stanza
    [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
    Car Totaled and i bought a 20G mp3 player
    http://machs-fuel.tk
    a DIY video projector page
    FLAC guitar333's Avatar
    Jun 2003
    IDAHO
    I fried an amp a while back and new I was keeping it for some reason, I have now decided that is going to be my case.
    92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
    93 Black SHO - 30mpg cruiser
    90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
    Aug 2002
    longview washington
    i would go looking for the cheapest p.o.s blown amp you could find that way if someone looks at it they will decide its not worth the time
    WINNER!!!!
    run-on sentance comp 2002!!
    Aug 2003
    PDX
    I had that same idea. I have been having a heck of a time finding one though. I am using one of the ITX boards, so I only need about 7x7x2. I finally got the idea to call one of my local car audio shops, and I can get one from them. You could also go with a diecast aluminum box, but they are hard to find much larger than the size I mentioned. They run you around $40 for one with 4mm walls and mounting flanges.
    Also, one thing to consider is ease of use. I think that the ampe heat sinks, with the open ended designs would be good because you could use plastic or plexy ends without having too much of an impact on heat, and they are much easier to cut than metal. Depending on the size of the box, you may want to cut out the rear faceplate for all your ports, or just have a hole where all the cords can come into the box and plug into the motherboard.
    If you do find a good source for the amp heatsinks, post it up.
    Aug 2003
    PDX
    Oh....I just found something
    http://www.rose-bopla.com/PMX/RSBPCa...c?OpenDocument
    The 7.72x4.17 would be plenty big for an ITX system. Wonder what the price is?
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    Go to a car-audio store and ask if you can have a blown amp, they sure got plenty of them
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Wow, those extruded boxes look nice. Fins are cool.
    Thought about the Amp case idea myself. Would look good alongside real amps in an in trunk custom rack install, with glassed in Subs and stuff.
    4x4 in a turbo stylee.
    Low Bitrate Linus's Avatar
    Oct 2001
    I assume part of the goal here is to eliminate noisy case fans and such as well as make it look good, fit in visually with amps, etc.
    In order for a heatsink-case to be effective, you'll have to thermally interface it with everything inside that generates heat. That probably means some kind of heat-conducting metal shim between the processor and the case, hard drive and case, etc. Having heat go from processor to air to heatsink-case to air would be very inefficient and probably inadequate for most processors.
    Might be tricky to do, but it's a great idea...
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    ummmm
    not sure bout ur mothaboards.... but getting the cpu 2 touch the case mite not be toooo goood. ur gunna need one whopping great big block of alumininum to do that.
    jst had look nw, it would have to be at least 2" thick to clear connections (if trring to mount to flat surface) thats without any cards in slot
