Results 1 to 7 of 7
Thread: MPXPLAY and EPIA boards
    Mar 2002
    Curious if there are any hardcore MPXPLAY users out there, and are you using EPIA boards? Specifically wondering if MPXPLAY supports the EPIA's in PURE DOS?
    Aug 2002
    I thought that I was the only one who has even considered this. MPXPLAY is the only program I've used since getting into this. It has all the features I want for dedicated mp3 playing, including crossfading. Even though my current setup is smaller and lighter than a normal desktop, I'm always looking to going smaller.
    I'm currently researching the use with a mini-itx epia board. Overkill for DOS and Mpxplay, but with prices getting lower this could be a very small, very fast mp3 player that has the ability to be a full blown computer when needed.
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    As long as you can get DOS drivers for the onboard sound, it should work like a charm.
    Mar 2002
    I'm with ya prerunnerv6. I have an older pentium biscuit board now, but I would like to go epia as I understand you can go without a fan on the cpu.
    Maybe one of these peeps that already owns one could boot to a dos floppy and find out for us?
    Mar 2002
    Comon.... been 2 months. This is easy to test for any epia owners!
    Constant Bitrate GRUNT's Avatar
    Sep 2002
    Scotland
    I used Mpxplay for a year, on my Epia c800,
    Onboard sound was NOT good.
    Installed cheap SB128 sound card, sound was much better.
    other than that I had no other problems.
    Dec 1999
    Buena Park, CA
    It is also quite possible to run Windows 98 in DOS mode (no GUI). I did this on my first generation machine, and it loaded MPXPlay using a callout to a batch file from autoexec.bat. This allowed me to do a couple of things, 1) have several batch files to control how MPXPlay loaded (with or without preloading songs, another to recurse the MP3 directory to grab new songs), 2) exit MPXPlay and type WIN in order to pull up the GUI for networking (used to troubleshoot as well as trasnfer new songs onto the drive). I would imagine that it would not be difficult to set this up on an EPIA board, again, the DOS mode driver for the sound card would probably be the hardest thing to find.
    KG6OQD
    www.americansandassociation.org
