Results 1 to 6 of 6
Thread: Does the EPIA5000 support regular drives & sound cards?
    Aug 2003
    Massachusetts
    By "regular" I mean going to BestBuy and getting an off the shelf hard drive and CD ROM drive that would work in any other PC.
    OR does the EPIA5000 only support certain devices?
    Jun 2003
    Atlanta/Augusta, GA
    Check the data sheet / specs and tell us.
    Low Bitrate Linus's Avatar
    Oct 2001
    Quote Originally Posted by tejesh83
    C'mon tejesh83. If you're gonna post, might as well provide some information.
    -al-, I searched google for "Epia 5000" and came up with this link. Next to "Onboard IDE" it says it supports ATA 100/66, which includes almost any hard drive or CD-ROM that you can buy. The exception is 2.5" hard drives and slim CD-ROMs, which require a simple adapter.
    Jun 2003
    Atlanta/Augusta, GA
    For all future spoon feeding, please PM linus. Can we make this a sticky?
    Aug 2003
    Michigan
    I have an EPIA 5000.. and I have it connected to an old WD 20 gig... ATA/66.. and I've connected it also to a newer Maxtor 40 gig.. ata/100.. both worked fine. i've also connected it with a 36x cd-rom and a 8x DVD-ROM.. again, both worked fine...
    the 5000 has an onboard sound processor... which works, and also a PCI slot that I've put an SB 128 into... and it worked...
    so I think it accepts pretty much anything standard.
    Nav
    Jun 2003
    I've got a Epia 5000
    So far I hooked up a 50x and 32x CDrom to it, worked fine. A 40gig WD HDD [Didn't like] and a 40gig Seagate Barra 4 which is loving it right now.
    I'm putting it in the car this weekend. It should be all ready soon
    Illusion: 2.4GHZ P4 @ 3.145GHZ | Gigabyte SINXP1394 | 256meg XMS3500 | SuperGrace 9500Pro
    PajeroPuter: Epia 5000 | 512meg PC-133 RAM | 30gig 5,400rpm HDD | 100w PSU & inverter | 7.5" Super LCD
