Results 1 to 4 of 4
Thread: My computer reboots when it wants to...
    Aug 2003
    I have a via m10000 with a 250 atx ac power supply and a 300watt inverter. I also run xp pro if you need to know...
    i also have 2 yellow top optma batteries powering the truck so power is not a issue.
    ok, i flip the inverter switch and the via bios loads and gets to the xp pro loading screen just beffor log on.. and cuts out and goews back to the via bios again. sometimes it won't even get to the xp screen... or sometimes it will load xp fine and at anytime in the xp session it will restart.
    any ideas???
    Variable Bitrate Sh0cker's Avatar
    Aug 2003
    LI, NY
    To make sure if this is not a power failure, just bring your computer home and connect it to the outlet (like a regular home computer). Then you'll see if its a power related or not.
    Danny.
    "If today was perfect, there would be no need for tomorrow."
    My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
    Apr 2002
    South Coast, UK
    Quote Originally Posted by sick98ranger
    any ideas???
    Yes, boot it up in safe mode connected to a standard PSU and look in the event log. I bet its blue screening, and XP is setup to reboot at system failure, so you dont get to see the actual blue screen. Look in the 'system' log.
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
    Aug 2003
    what should i be looking for exactly for in the log. error type, cat #, event id #, ????
    i did get a system error when it did this. system error cat 102 event id 1003 and blah blah for the err code 0000000c5, p100000000, p2 000000002, p3 000000001, p4 80537213.
    and just befor that is an information log for a save dump.
    peace
