I have the same probs, i dont think there is a BIOS option to disable the network boot screen, it never showed up before I updated my BIOS. So I would try going back a previous version or 2 of the BIOS (which is what Im gonna do)
I'm using the via 5000 with the eden 533 Mhz... and when i boot, there are a couple of things that seem to be slowing down the bios to OS transition.
1) it says "Press <ESC> key for network boot options menu" and waits for a few seconds. is there any way to disable this? i've been through the bios settings and found nothing.
2) i get some sort of PXE-61 Media failure message, and then PXE-61 exiting message. don't know what this is either. i can get the specific message if that'll help anyone.
other hardware attached is just the harddrive (WD 13 gig)
any help would be appreciated. thanks.
Nav
92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
93 Black SHO - 30mpg cruiser
90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
If you hit the key it says to edit the options (I forget it now.. don't have it hooked up to see) You have the option for it to boot local drives first before trying to do a PXE boot (network boot). The delay is the PXE boot rom trying to find a DHCP server to get an address and info from where to boot from.
I have the same MB and same issue...
grrr....
astral
This is your life and it's ending one minute at a time...
well its nice to know i'm not alone... tragic though.
anyway, as per callahan's instructions, i hit the esc key to go to the network options... and you CAN put local drives first. EXCEPT it only holds for that boot. i'll try to get an answer out of VIA and let you guys know.
Nav
I have the m10000, I know I had the pxe net boot coming up at one point.
My car is in the shop at the moment, but I know I was abe to disable this option.
Odd, it went away for good for me..Originally Posted by Nav_Attack
not me, callahan what MB do u have?
the 5000.. I'm a little scared to even go in and look at the options to break my "good luck"Originally Posted by guitar333
Originally Posted by Callahan
did you SAVE the settings![]()
[H]4 Life
I'm a lesbian too.
I am for hire!
