Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Need some help with sending audio to stock amp
  1. #11
    Newbie PFDarkside's Avatar
    Aug 2003
    Somewhere around Detroit...
    I don't mean to rain on the parade here, but if I'm reading this correct, it says connect an aftermarket radio as you normally would. This indicates to me that the Nissan Amplifier is actually taking it's signal from speaker level signals. Your mobo is outputting line level signals. There may be a buffer circuit of some sort inside the amplifier and an automatic gain circuit that will allow the use of a line level signal, but I'm not too confident about it.
    Also, assuming that you had a "regular" aftermarket amplifier, you would still need to connect both the signal and ground to + and -. If you don't, you'll probably get a lot of hum. It may work, it may not, but that ground (-) is the reference for the music signal.
  2. #12
    Aug 2003
    Did you get that 1/8" stereo -> Dual RCA jack yet?
    I have one and I have a lot of line noise now.. I tried both with my laptop and a RIO mp3 player. Both had similar line noise.
    If you splice wires into line level inputs, my guess is you'll get insane hum/line noise...
  3. #13
    Maximum Bitrate orangewhip's Avatar
    Apr 2001
    Surrey, B.C. Canada
    So my only option is to get an aftermarket amp??
    OrangeWhip? OrangeWhip? 3 OrangeWhips!!
    Finally a new Avatar!
