Results 1 to 10 of 11
Thread: So, do VIA motherboards support expansion such as sound cards?
    Aug 2003
    Massachusetts
    I am debating getting a VIA motherboard (M1000N) or a conventional ATX size board. The only drawback I see with the VIA is that you can not use a good sound card, your stuck with on board audio.
    It seems that if you are going through the expense of a carputer, you minght as well use a good sound card, no?
    Aug 2003
    Massachusetts
    OK I feel dumb for posting without researching first...It seems that mobo has 1 PCI slot from the looks of it.
    Apr 2003
    Canada
    If you use one of those two slot pci risers you can have two pci slots.
    Aug 2003
    Massachusetts
    Oh you can? Thats cool..I assume there is no conflict issues when you do that? The processor does not care that there are 2 devices on one slot?
    -AL
    Aug 1999
    Washington D.C.
    You might want to consider a USB sound device.
    Aug 2003
    Massachusetts
    I wonder if the ISB sound devics are as high quality (as far as audio quality) as a similar PCI device?
    Aug 1999
    Washington D.C.
    Quality USB sound devices ones can be better then an internal sound card because they are separated from the electrically noisily inside of a computer case. USB sound devices tend to be CPU intensive, but that won’t matter with faster systems.
    Aug 2003
    Massachusetts
    Thanks zip-lock. I was leary of USB sound cards but now maybe I'll look at them. I wonder if the creative audioligy 2 USB version is as good as the m-audio usb card?
    -AL
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I am not personally impressed with the M10000 sound...maybe it is the shielding, don't know.
    Poke around www.mini-itx.com for some more info.
    I am using a video card in the pci slot, so if I was to impove the sound I would go usb.
    I haven't heard good things about the two slot risers.
    Maximum Bitrate PTCruiser's Avatar
    Oct 2002
    Switzerland
    EPIA M use the newer VT1616 wich is far better than the non M epia...
    Soud quality is already correct....
    http://www.mini-itx.com/reviews/nehemiah/?page=9#s18
    You may chg it for a audigy 2 or better with any Via envy24 card (M-audio, terratec)
    You have riser card for 2 PCI....
    Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
