Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: 3rd Dead HD, What Gives?
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Question 3rd Dead HD, What Gives?
    OK. I have a problem. My first desktop drive died and was replaced on warrantee. The second drive died and I just went out and got a laptop drive. Now the laptop drive has died. What gives? I have been thinking that it is my mounting system. Since the majority of people seem to have their players hard mounted intead of shock mounted, that may be the difference. Could the springs I have the player mounted on actually be causing more problems than they solve?
    I am hoping to get this drive replaced on warrantee, but I would not like to repeat this experience again. As it is, the drive is completely dead and I will most likely have to reload from scratch. This is a large **** off.
    moahdib's Avatar
    Jul 2000
    Post
    I never had a problem with HD. Not even bad sectors for over a year now. I don't even have any sort of shock protection, the HD is mounted vertically in a bookPC and I have some foam underneath the box. Perha[ps it could be your sound system interfering or powersupply gone bad.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    May 2001
    Post
    aaron: maybe it is the shock protection. how was it setup? I can picture in my head how TOO MUCH bounce could have a negative effect on the hard drive...can't really explain it but i'm sure you know what i mean. basically you want it to give a litttle, but not enough so that it's bouncing around everytime you drive over a pebble.
    Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
    Aug 1999
    Upper Marlboro, MD 20772
    Cool
    i am sure it is the mount....and moahdib i am sure it is that foam that is keeping ur HD alive up until now. Also i suspect you dont drive ur car really hard or maybe u have a very well designed suspension.
    abcd-1
    Jul 2001
    Post
    Yeah, probably the "suspension" for your player... No-one else has it, and no-one else has problems..
    Mar 2001
    Post
    I have no suspension system. No foam. My laptop HD (IBM) is just screwed into (laying flat) into the computer, which is sitting on the floor of my trunk.
    No problems with the drive. No bad sectors.
    I do get other problems, though. :/
    Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
    Car: 1993 Nissan Maxima, Black Emerald
    Aug 2001
    Olympia, WA
    Post
    Do you have low profile tires on your car? Is the suspension rough? It could be the car causing the unecessary vibrations. But then again, it could be mounting.
    I have mine mounted in foam vertically in a computer case and the only problem that I have is when my subs are pounding too hard the computer just freezes up.
    BoominVolvo
    http://olymp3.mp3car.com
    Maximum Bitrate PoBoy's Avatar
    Jun 2001
    St. Louis-MO
    Post
    My HDs were dying all the time due to the "washboard roads of Detroit, MI. So I went to a comp show and bought 15 540mb HDs for 5 bucks each. Those babies run Windows. When they die, I just pop a new one in. As for all my songs and stuff, I have one of those external jobbies. Put that in some egg shell foam stuff and it seems to be fine.
    Suspensions for your comp sound like a good idea, but if they just prevent hard shocks to your HD but cause lots of freely moving around - its probably not any better. Analogy: If you get carsick easily and get on a swing - even though its a smooth ride you are still gonna get a little queezy...eveyone get that analogy? Sorry if ya dont. Its late and I am getting my fix before a long weekend with no mp3car.com
    PoBoy
    I'm a ghost...email me if you have any questions on my old setup
    My way outdated website: http://www.poboytech.net
    FYI: I sold my 96 4Runner and bought a 1985
    Jul 2001
    Post
    What happens when you run out???
    Jun 2001
    St. Louis-MO
    Post
    I go through 2 maybe 3 a year. 4 years from now I might be out. By then I will assume that all of our HD troubles will be fixed.
