Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Where to find dead amps
  1. #11
    Aug 2003
    PDX
    Quote Originally Posted by Brayden
    Might be noob question here.. but for what?
    for using as a case for your carputer.
    if you use a heat pipe to cool your cpu and other components that need cooling, and connect the heat pipe to the case itself, then most of the heat will be disapated to the outside of the case, just like how an amp works.
    amp cases are usually thick extruded aluminum with large heatsinks attached, so they offer protection as well. that way you can keep your computer in your trunk and not have to worry too much about it getting banged up.
  2. #12
    Aug 2003
    Indiana
    Cool.. Thanks..
    I have the resources and knowledge to build aluminum cases like this. Are you guys interested?
    Here's a pic of a cooler that my buddy designed for cryo-cooling. Would be nice for a peltier array to liquid cooler.
  3. #13
    Aug 2003
    Indiana
    another pic
  4. #14
    Aug 2003
    Indiana
    one more
  5. #15
    Constant Bitrate Lando's Avatar
    Apr 2002
    As some great woman said "my level of intrest depends on the size" How big an amp you talking?
  6. #16
    Aug 2003
    Indiana
    This will be a custom aluminum box, with heatsinks on it.. Any size you want...
    24x12x4.. anything..
