You need to double check that, as you'll need an AUX input to run sound from your laptop into it.i will be getting a brand new laptop in about 3 weeks, and i have an alpine cda-7893 headunit which has an AUX output.
Should work fine, I've been enjoying my X10 mouse remote (RF) now that I found software to have it run under XP.im thinking about getting a small monochrome lcd display to scroll just the song titles, and get an RF remote to switch between songs
Yes, but depending on the laptop model, you may need an adapter from the manufacturer (as some don't take 12Volts directly)i assume that because it is a laptop, i can just use a carcharger to power it, correct?
Not sure on this one, definately look through your manual when you get it to see if there's any options regarding going into hibernation when it's not getting power, and coming back on when power is restored.also, will there be any way to set it up so that when i turn the ignition off, the laptop will go into hibernate mode? and when i turn the ignition on it will come back up?
LinkBack URL
About LinkBacks
