Results 1 to 3 of 3
Thread: Slim/Slot Question
    Constant Bitrate Lando's Avatar
    Apr 2002
    Slim/Slot Question
    OK, I want my comp in the trunk and my DVD in the Dash. The best way I found to make this happen in an ATAPI to USB adapter conected to the Slim ATAPI to STANDARD ATAPI adapter thats already there. Here's the question:
    Once I connect the power cable etween the adapters WILL THE USB 2.0 CABLE SUPPLY THE POWER FOR THE DRIVE or will I have to find some way yo run a power connecter all the way back to my comp?
    Maximum Bitrate churnopol's Avatar
    Apr 2003
    Delaware!!!
    you will have to find some way to run a power connector back to you comp. Unless you have an enclosure. An enclosure comes with it's own psu with an on/off switch
    Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
    Better than winamp. Click here for qcd player.
    Newbie carplayer.nl's Avatar
    Aug 2003
    Netherlands
    I also have an USB 2.0 interface on my DVD-drive. First of all I used an slim-line -> IDE convertor. I bought a case for an external Drive and used only the interface card. The power for the DVD-drive and interface card is needed beside the USB power. So you have to make 4 extra cables from the comp to the front. You can draw the power from the power cable inside the computer case. It contains +5V -5V -12V +12V.
    Then it should work.
    By the way you should connect an USB 2.0 device to a USB 1.0 Hub cause the motherboard fails to boot.
    Jan Hoff ( www.carplayer.nl )
    EPIA M10000N | 256 MB | 120 GB | DVD-ROM | 7" Touch | OBD-II | IrMAN | WinXP | DC-DC 9V-18V | 4x200 Watt AMP | 400 Watt SUB
