Results 1 to 6 of 6
Thread: Slimline IDE Adapter - How does it work?
    Aug 2003
    Question Slimline IDE Adapter - How does it work?
    How the heck does this thing work??
    My slimeline HDD has 44 pin holes and then 4 other pins to the side.
    The adapter has the small end with 44 pins and plugs right in, but it says "pin1 (to HDD)" so I am sure it is installed facing the right direction.
    The other end has 40 larger pins for normal IDE, but the IDE cable has 1 center pinhole blocked (normal IDE). Do I need to break that pin off (some of you call it a "security pin") from the adapter so it fits or what???
    WTF?!?!
    HELP!!
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    no manual? ask the store or makers
    Aug 2003
    I bought it off Ebay... They showed it plugged right into the IDE cable, but that is not possible unless I break off this pin. I'm sure it's OK, because it isn't hooked up to anything at the other end.
    Banned outragis's Avatar
    Jul 2002
    Vermont
    I had to do the same...It will work fine!
    Variable Bitrate MeanGT's Avatar
    Jul 2003
    Melbourne, Florida
    Quote Originally Posted by sq_geek
    I bought the exact same one also off eBay, just make sure you break off the right pin
    Aug 2003
    cool, I did, and it works.
