Radeon 7000 PCI
Ok, I just put in my new ATI Radeon 7000 pci video card with tv-out into my carputer system so that I can get better resolutions and dvd playback.
The problem is that the card won't detect my TM-702L display!
Does anybody have this card that can help me out with this problem?
Make sure you are using a 70Ohm RCA cable...
I think thats the right number???
EDIT: OK it was 75 Ohms... :rolleyes:
how do i know if it's 75 ohms. The cable I am using worked with the epia's tv out fine!
check it with a multimeter
sometimes the radeon cards are picky
try to turn the screen on before you boot up the pc. My old rage128 is like that. Just a suggestion though.
I finally got it to work with another cable but the thing is that it won't pick up the lcd right away.
I had to connnect it to my tv at home, it detected the tv, and then i switched the cable to the lcd.
Thats the only way it would work. I also can't figure out how to get it to boot up through the tv out.
I know this has been covered many times before. I did a search for 'video 75ohm' and here is the link. click me
Steve
