Results 1 to 5 of 5
Thread: Routing power button to front of PC. Can wire be too thick of gauge?
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    For my v1.0 CarPC I ran the power button, reset button, and LEDs off a CAT5 15 foot cable and everything worked fine.
    For my new v2.0 CarPC I was given by a friend a 4 conductor cable that has 16 gauge wires inside. Two of them I will use for the Power Button. The other two I am using for a amp turn-on lead hooked up to my HU, and the other wires is going to be Ignition on to hook up to the shutdown controller.
    Will the 16 gauge be fine for hooking up the power button? I would think that the signal might get lost since the gauge is soo thick. Sorta like a resistor. But I may be wrong. Any comments?
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    Yeah that makes no sense LOL. There is no such thing as a gauge to thick. Think about it as the wire is a highway. The voltage is the cars. The wider the highway, the better the traffic right?
    You'll be fine. Set that bad boy up.
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Actually, you should get less resistance going from the 24awg cat5 to the 16awg if I remember correctly. 24awg has something like 25ohms of resistance per 1000ft, where 16 gague has something like 4ohms per 1000ft.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    No problem here.
    The opposite is the problem...running too much power over too thin a wire leads to overheating...and eventually fire...
    However the computer power and reset switches draw a tiny bit of power.
    Jan 2002
    Long Island, NY
    Thanks for the quick replys and reasons.
    I'm getting so bored without my CarPC installed. I miss it.
    Wires half way ran. Yipee. This setup is so much cleaner than my 1st!
