Results 1 to 6 of 6
Thread: WinAMP as a shell
    Aug 1999
    WinAMP as a shell
    How do you do this?
    Jul 1999
    Decorah, IA, USA
    Open your system.ini file (Run -> sysedit.exe) and find the line that says shell=explorer.exe. Replace explorer.exe with winamp.exe (you'll probably need the full path, usually c:\winamp\winamp.exe or something similar). I must warn you that when you do this, you won't be able to run anything except WinAMP. If you want to boot into the Windows shell, you'll have to edit system.ini in DOS mode to say explorer.exe again.
    Jul 1999
    Oakville Ontario Canada
    Similar to JupiterX's solution, i just added the path of the winamp.exe to the autoexec.bat file, ie.
    PATH=c:\dos;c:\windows\;c:\progra~1\winamp\
    (remember the dos 8.3 file conventions when doing this)
    and then in system.ini deleted SHELL=Explorer.exe and replaced with SHELL=winamp.exe and voila! Winamp on it's own.
    Aug 1999
    Yorba Linda, CA
    One thing I've found helpful in fiddling with the SHELL= variable is to comment out the line (place a semicolon ( as the first character on the SHELL= line) instead of deleting it. Then I can just switch my comment marker ( and reboot the system back into normal Windows for testing/debugging and to get access to explorer again for copying MP3s from my home system to my car PC.
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    MPC Phase IV - *** PENDING ***
    Aug 1999
    jjohnson... can you post an example of how that would look?
    Aug 1999
    Yorba Linda, CA
    Sure, check it out:
    Open up the SYSTEM.INI file in your windows directory (usually c:\windows) with notepad or another text editor (DOS EDIT works fine too)
    To boot normally, do this:
    <pre>
    [boot]
    oemfonts.fon=vgaoem.fon
    system.drv=system.drv
    drivers=mmsystem.dll power.drv
    shell=Explorer.exe
    ;shell=c:\program files\winamp\winamp.exe
    user.exe=user.exe
    </pre>
    And to boot straight into WinAmp with no desktop icons or taskbar, do this:
    <pre>
    [boot]
    ;shell=Explorer.exe
    user.exe=user.exe
    </pre>
    It's that simple and it works fine for me
    The exact lines and location of the "SHELL=" setting may vary as this is from my COMPAQ PC at work.
    --Jason
    http://jump.to/m2pc
    Jason Johnson
    http://www.m2pc.com
