Sounds a little hot to me. Standard temperatures are between 30 and 45 or so. Do you have a good heatsink? Did you use heatsink goo on the bottom? Even if it had a pad, you should remove the pad and use the goo instead. It's much better. A larger fan might also work. Are you running too much voltage through the chip?
LinkBack URL
About LinkBacks
