Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: a/c air to the trunk?
  1. #11
    Nov 2000
    Post
    Wouldn't this be a risky thing to do? Hooking up a direct air source from your A/C into your carputer? I'd think that the possible condensation would be a much greater risk than heat. Perhaps piping the A/C into the trunk itself would be better to allow a gradual temperature drop?
  2. #12
    Jul 2001
    Richmond, VA USA
    Lightbulb
    Depending on availability, and the space you have... you could always try to find an old rear A/C unit in a junkyard... many conversion vans have these... but unfourtunately I can assume many get picked up quickly or have many leaks... but its worth a try. Of course if you have too much money to know what's good for yah, you could probably get one from a dealer. Just a suggestion since running a tube seems to be hard. The only problem I see with the fans under the backseat to the trunk is the back of the car usually doesn't get cool enough quick enough, or at all if your A/C really sucks...lol
    I'm sure someone out there has a good idea on how to do it... I'm actually really interested in the idea now even though I drive an SUV and dont have a trunk. It could be useful no matter where the computer is just to make sure you don't have any skipping problems... a cool computer is a happy computer!
    Josh Karger
    By reading this post you agree to overlook all grammatical, spelling, and typographical errors! ;)
  3. #13
    Newbie elmo_eats_rust's Avatar
    Mar 2004
    Minneapolis, MN
    I would try using a water cooling system and extend the tubes, this way you can hide the tubing and get a decent setup. Just have the radiator of the water cooler in front of one of your AC vents, or you could even put it into one of your AC vents if you wanted to.Also, you may want to add antifreeze to the water. You would also need to make sure that your connections are tight, your tubes won't get squished and your pump has enough power to move the water.
  4. #14
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    Since I live in florida and with august coming, I need to cool my system quick. Other wise it will cook in the trunk. Since some people are interested in cooling their trunks, this is what i plan to do before my carputer catches fire. (yes i already had one do that).
    http://www.swampy.net/12vcombo.html
    check it out, see what everyone thinks. Little maintenance though.
    Opinions?
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
  5. #15
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    ok i think this is a very bad idea, evaporative cooling works by doing just that, it evaporates water into the air, which makes the air very moist, this can lead to your computer getting moist and we all know what happens then. on the other hand air conditioning take the moisture out of the air, so its perfectly fine to use to cool a computer, i dont know where these ides come from that air conditioning will cause condensation on your computer unless you cool the computer to very cold then turn the air con off there shouldnt be any condensation.
  6. #16
    Mar 2004
    Metamora, MI
    search a race car supplier (pegasusautoracing.com is one) for hose that is used for brake ducting. Comes in 10 ft lengths and is heat proof. But, the stuff I have used is about 2 inches in diameter.
  7. #17
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Holy thread resurrection, batman!
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
  8. #18
    Mar 2004
    Fort Myers, Fl
    ok how about this?
    http://www.spacepak.com/html/spacepa...ble_tubing.htm
    got to come up with something. starts getting hot in florida after july.
    Dont want something like this to happen.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
  9. #19
    Constant Bitrate gubon13's Avatar
    Los Angeles
    i assume there's a good story behind that picture... my guess is god smote you for looking at too much porn? lol...
    "Is Wayne Brady gonna have to choke a b@$#*??!!"
  10. #20
    Mar 2004
    Fort Myers, Fl
    relax not mine, found it online. But I dont want something similar to happen to me. Just added 4 more fans to my carputer today.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
