Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: best sound possible
    Newbie jettamasta's Avatar
    Sep 2003
    Question best sound possible
    how can i produce the cleanest, loudest sound possible with a carputer? will i need to go through a head-unit? what sound card should i use? i have already chosen amps and speakers, i just need to know how to get the best signal to the amps as possible. thanx for any input
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    I believe you can do it two diffrent ways:
    1. Use a head unit with an auxillary input. Connect this input to the output of of a high quality sound card plugged into the motherboard's PCI slot. For AM/FM, just use the HU, for MP#'s use the AUX input.
    2. Don't use a head unit, Use a High-quality sound card, and a TV/FM tuner PCI cards. Connect the output of the soundcards via a stereo mini-plug to RCA adaptor to your amps.
    FLAC guitar333's Avatar
    Jun 2003
    IDAHO
    or to a pre amp and then to the amps
    92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
    93 Black SHO - 30mpg cruiser
    90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
    Registered User SWYZ721's Avatar
    May 2003
    Quote Originally Posted by guitar333
    Ya mean like an EQ or somethin? Hmm another benefit to get the audiocontrol
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Quote Originally Posted by SWYZ721
    I am using the digital out to an Alpine PXA-H700. Works awsome. Does EQ/Crossover/Dolby Digital/DTS.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
    Maximum Bitrate churnopol's Avatar
    Apr 2003
    Delaware!!!
    This is the best sound card, Creative Labs Sound Blaster Audigy 2 Platinum .
    http://www.newegg.com/app/viewproduc...iption=SB0240P
    The best sound cards have 24-bit & 192kHz and spdif outputs which this card has
    Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
    Better than winamp. Click here for qcd player.
    Jun 2003
    Atlanta/Augusta, GA
    Can someone explain the digital setup. How do you use the digital out on a Audigy 2 or M-Audio Revo in a car? What equipment do you need? Advantages/drawbacks? Is it better than analog, why/why not?
    Aug 2003
    Massachusetts
    Unless your amp or head unit has a digital input, how do you plan on using the digital output of the sound card? Unless you put it through a d/a converter, but then what would be the point?
    -AL
    * 2000 Ford Expedition
    * EPIA M10000/512 meg RAM, Win XP PRO, 90w OPUS, 80 gig HD
    * TM-710VGT LCD, Wireless mouse, keyboard
    * M-Audio Sound Card, 2 Alumapro 10" subs, 2 PPI Amps (1kW)
    Jun 2003
    Atlanta/Augusta, GA
    I found some of the info I was looking for here:
    Digital Audio Updates?
    al:
    At some point, most audio is converted to analog if not all. My ears don't understand the 1s and 0s on cds or in mp3s yet. But there may be an advantage of delaying the conversion.
    Jun 2003
    IDAHO
    my idea of a good setup is:
    -a good signal out from a good soundcard (audigy, mp3+ etc)
    -a shielded RCA to 1/8" stero plug converter cord
    -a nice headunit with RCA aux input, front, rear, and subwoofer RCA output.
    -a good 4 channel amp for the speakers
    - and a nice mono amp for the sub(s)
    or you can do it w/o the headunit using a preamp
