USB Hub
with or without external power.
hey guys
i was wondering how can i power the digitalww touchscreen, a usb soundcard and a external dvd drive with one sub port. i also have a pcmcia usb card. that card can't power the touchscreen or the soundcard, but it can power the dvd drive. what do i do about the usb soundcard, since i'm gonna have the touchscreen plugged into the one usb port?
project: built, updating software
comp: 1.67 ghz AMD, 1 gig of ram, 80 gb hd
software: nlited xp, roadrunner
screen: TM-701L touchscreen
bluetooth keyboard
Sony Xplod cdx-m630
SB MP3 sound card
future: gps with and navigation software
USB Hub
WITH
had problems running one without
A powered USB hub should let you power everything just fine. Most of them run off 5volts. Make sure you have clean power for this 5 volts because it goes right out to your devices with little to no conditioning. If it surges, you'll fry everything on the hub and possibly your computer too.
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
running it off an inverter would not be a good idea would it?
bluetooth keyboard
Sony Xplod cdx-m630
SB MP3 sound card
if you have a good power inverter, it would be better than just running it with a DC stepdown power supply. the power inverter is less likely to surge than straight through the car's electrical system.
what if i connect everything to a surge protector off my 90 watt inverter?
bluetooth keyboard
Sony Xplod cdx-m630
SB MP3 sound card
If you use an inveter you should be more then fine. It will give you 2 levels of protection. The inveter itself, And then the wall wart that steps the power down to 5V DC. I wouldn't worry at all if you did it that way. The only thing is that using that sort of setup, you might get interference in your stereo system.
