1) you answered your own question. It will work, but you may need gain adjustments for each input.
2) I know mine does..... just have it switched before the inverter like most ppl do.
1) Is there any problem with simply running RCA cables from the back of several appliances (in this case a Playstation, PC and Pioneer CD headunit) into some sort of RCA source selecter and then straight into the back of a car amplifier? I ask this as i'm concerned about the possibility of the RCA signal volume levels differing, therefore requiring seperate gain levels to be established for each input!
2) Does the inverter constantly draw from the battery when its connected even if the attached device (ie. computer or playstation) is turned off?
The box said Windows 9x or better.. so I installed Linux
There are 10 kinds of people in the world those who understand binary and those who don't.
Project - GAME OVER :(
Just make sure you use high-quality, well-shielded RCA cables.
PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
BC ROCKS!!!
okay so I need to have different gains settings just how do I implement that? and will running the coputer sound via the line out, will that remove the problem with that appliance?
